I purchased the Celestron 2.5X Luminos 2-inch Barlow because of its light weight and smaller size, and I've been using it for the past two months.
Performance has been quite good for me and it's working well with the Ethos, Leica, and long focal length XW eyepieces to give magnification values that I can't get with my current eyepieces alone.
This post is only to show the magnification values I get in different configurations. More information about the Luminos Barlow can be read in this archived thread: https://www.cloudyni...centric-barlow/
I'm also including values I get with the AP BARCON screwed onto the end of the eyepiece as noted, because that also gives useful results when minimizing the number of eyepieces carried out.
ETHOS
First, please note that I have a Tele Vue 30mm 2" barrel extender on the 6mm, 8mm, 10mm, and 13mm Ethos eyepieces to cover the 1-1/4 barrel that extends beyond the 2" barrel. When using Ethos with the Luminos Barlow, the barrel extender prevents the 1-1/4 barrel from contacting the Barlow lens.
Inserting the Ethos with 30mm barrel extender into the Luminos 2.5X Barlow results in different power factors for 6mm / 8mm Ethos vs. 10mm / 13mm Ethos due to the focal plane position.
- 2.26X magnification increase in the 6mm and 8mm Ethos
- 2.46X magnification increase in the 10mm and 13mm Ethos
Therefore, the 6mm, 8mm, 10mm, and 13mm Ethos with the Luminos Barlow gives 2.7mm, 3.5mm, 4.1mm, and 5.3mm, all at 100o AFoV. I find the Barlowed 8mm Ethos perfect for my TV-85 f/7 refractor, because it results in a 0.5mm exit pupil at 100o AFoV.
To attach the AP BARCON lens cell to the end of the eyepiece typically requires a 10mm M48 extension to be added to the BARCON to extend the M48 threads out beyond the T2 threads. However, attaching the BARCON to the Ethos requires a minimum 20mm M48 extension tube. I do not use the 30mm TV barrel extender because in this situation, I want a short path to reduce the power factor of the BARCON, so 20mm it is. The power factor is different for the 6mm / 8mm vs. the 10mm / 13mm due to the focal plane position as mentioned above.
- 1.19X magnification increase in the 6mm and 8mm Ethos attaching the BARCON to the Ethos with a 20mm tube M48 extension
- 1.30X magnification increase in the 10mm and 13mm Ethos attaching the BARCON to the Ethos with a 20mm tube M48 extension
Therefore, the 6mm, 8mm, 10mm, and 13mm Ethos with the BARCON and 20mm extension tube screwed onto the Ethos directly gives 5mm, 6.9mm, 7.7mm, and 10mm. For me, the 6.9mm is a nice split between the 6 mm and 8mm Ethos. The 5mm, is a slight bump up from the 4.7mm Ethos eyepiece if needed.
Note that my 20mm tube extension doesn't fully seat into the eyepiece, so some minor variance is likely with different brand extensions.
I find that the Luminos Barlow is more convenient to use than the BARCON because I don't need to screw anything onto the eyepiece - just slip it in.
LEICA ASPH ZOOM
Adding the Luminos Barlow to the Leica ASPH Zoom with the Starlight 2" adapter increases magnification by 2.55X, for a resulting 3.5mm - 7mm zoom, with the 3.5mm end being at 75o AFoV. This is a nice complimentary range to the Leica 1.8X Extender, and I use them both.
Pentax XW 40mm
Adding the Luminous Barlow to the 40mm Pentax XW results in a 2.51X magnification increase, or a resulting 16mm focal length at 70o AFoV.
Adding the AP BARCON cell to the end of the 40mm Pentax XW using a 10mm M48 extension tube increases magnification by 1.43X resulting in 28mm focal length at 70o AFoV.
When minimizing eyepieces with my AT60ED f/6 refractor for travel, but having enough room for two larger eyepieces (rather than Delites) and the Barlows, the 40mm Pentax XW and Leica ASPH Zoom with the BARCON, Luminos Barlow and Leica Extender provide everything from low power 7.4o TFoV up to 102X at 0.74o TFoV, which is getting close to the power limits for the small scope.
In the Ethos line, the Luminos and BARCON options enable me to reach many intermediate focal lengths while maintaining the 100o AFoV.
I still prefer the ease of using separate eyepieces without a Barlow, but it's very nice to have the optional focal lengths when wanted.
Final note -- my measurements are accurate enough for me, but might vary a percent or three from actual, so if precision is needed, please remeasure with your equipment.
Gary
Edited by GGK, 01 July 2022 - 06:53 PM.
