CEM 60 Periodic RA drift
Equipment Mount Imaging
7 replies to this topic
#1 dsullivan
dsullivan
  • Loc: West Hartford CT
Posted 03 July 2022 - 07:41 AM
I'm having trouble with what I believe to be backlash in my CEM 60's RA. Since the backlash is periodic I believe the issue could be caused by damage to the RA gearing. The RA assembly has been dismantled and inspected, however I am unsure if there is damage to the ring or worm gear.
  • Previous sessions ran flawlessly with the exact same OTA/setup/configurations and I am unaware of any incident that may have caused this issue to begin occurring
  • All imaging sessions from the past month now produce unusable subs (300s) displaying star drift in both directions
  • This occurs when imaging targets in different sky locations
  • When the RA is engaged, there is no observable backlash or play when pressure is manually applied in either direction
  • Backlash occurs periodically, suggesting damage/flaw with RA gearing
RA Worm Gear Inspection Video
There doesn't appear to be any damage to the worm gear.
RA Ring Gear Inspection Video
There appears to be some wear to the ring gear but no drastic damage, though I'm not entirely certain of this assessment.
PHD Guiding Assistant Backlash Example Video
You can see the severity of the backlash, and how it occurs in regular intervals.
Imaging session examples
PHD showing periodic backlash:
5min sub with star drift from backlash:
#2 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 03 July 2022 - 08:03 AM
Have you carried out a PHD2 Guide Assistant run of several worm turns, to show the mount's inherent RA behaviour ?
Have you got PPEC engaged ?
Is it a good model ?
Is RA better without PPEC ?
Couldn't open your videos, a PHD2 GuideLog would be more instructive.
#3 dsullivan
dsullivan
Posted 03 July 2022 - 08:46 AM
Yes, the PHD Guiding Assistant Backlash Example Video I linked to shows 11 minutes worth of tracking, I'm assuming that's a few worm gear turns, and you can see the RA behavior repeating itself a few times.
https://drive.google...s_MKNgfsKa/view
I have the base level CEM60 which does not have PPEC
Not applicable
Not applicable
They are links to videos on Google Drive. I tested them on different devices and accounts. They might take a second to load but they provide much more information for troubleshooting.
#4 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 03 July 2022 - 05:48 PM
PHD2 has a PPEC algorithm for RA guiding that should take care of such periodic variations, however, as they are quite large and steep, you'd need a quite fast cadence, i.e., short exposures.
Usually the culprit for periodic error is the worm gear, for strong excursions sometimes even only some dirt (or bug...).  RA backlash shouldn't be there for a CEM60, unless the belt tension is wrong (*) or the magnetic meshing isn't adjusted properly.
(*) have you checked that?  In doubt attached is the iOptron manual for doing that
#5 rjsc2000
rjsc2000
  • Loc: Portugal
Posted 04 July 2022 - 03:48 AM
I don't have the mount but if that error is periodic, can you mark the worm with a marker when it makes that spike? And check when it happens again, if it's in the same spot. You can also check the bearings
#6 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 04 July 2022 - 04:12 AM
The GA video in post #3  shows some fast RA excursions.
Use the GA  Frequency Analysis to measure the frequency.
Some belt-drives have fast harmonics, eg 7 secs, that are too fast for PHD2 to correct.
Often reduced by belt adjustment, or moving the belt along a few teeth.
#7 Malbrough
Malbrough
Posted 04 July 2022 - 02:38 PM
Been experiencing this on my cem60ec. Just did RA adjustment mentioned above, will report results soon.
#8 Malbrough
Malbrough
Posted 04 August 2022 - 12:59 PM
My problem turned out to be a combination of bad seeing conditions and my polar scope crosshairs being out of line. I did the ioptron polar scope alignment, and all is well.
Was a bit tedious of an alignment, but figured it out. Removal of the polar scope was not needed, just removed the bubble level and tweeked the 3 hex screws little by little to center the crosshairs.
Also tagged with one or more of these keywords: Equipment, Mount, Imaging
