SVX140 and TEC140 side-by-side
79 replies to this topic
#1 Bkmiller4463
Bkmiller4463
  • Loc: Salt Lake City
Posted 07 July 2022 - 08:57 PM
Had a great night out with the SVX140 in Torrey Utah. A new friend had their TEC140ED. Our VRBO host mentioned they had a guest at another one of their properties who was in town for the same reason as we were, so we connected and agreed to meet. Interestingly, we both had a Planet with an extension, my DM6 and her AZ100, and the same diagonal, so the comparison was on a truly level playing field in that regard.
First let me say we didn’t account for the small f/l difference (938 vs 980) in other words we didn’t attempt to perfectly match magnifications. It was close enough however, and I can’t imagine the small difference had any bearing on our impressions of the scopes. The eyepieces were mine, and we swapped between scopes.
The night was great - average 21.96 SQM (her meter) over half a dozen samples after the moon set. Very good transparency with some smoke down low, early clouds, good seeing. Very light wind, 70F degrees decreasing to 63F by 1AM. 50% cloud cover early, mostly gone by 1AM. No light domes visible in any direction, but the night was quite “moony” especially due to the cloudy sky, so we focused our comparison toward the northeast when we weren’t looking at the moon.
Our first impressions of the other’s scope were the same - “nice piece of kit”, “looks just like mine”, etc. The TEC felt noticeably lighter, if a bit longer. The SVX feels subjectively more “solid” but I really liked the weight advantage of the TEC. Only a couple of pounds, probably, but noticeably easier to uncase, lift and mount, not that the SVX is exactly difficult. The rings were similar, with the TEC having a sort of latch mechanism vs the SVX hand knobs. She liked mine better, I thought they were about the same.
On closer inspection both scopes were extremely well-finished with flat white tubes and consistent anodizing. I liked the focuser end of the TEC better than my SVX, which looks a bit steampunk with its exposed adapter/reducer thread. The focusers were both FTs, but I thought the diagonal attachment collet on the TEC was better than the triple screws in my SVX. I like the objective cover better on my SVX; it’s a simple “hat” vs the TEC’s insert, which, while very well-engineered and tight-fitting, seemed a bit fiddly to me. I felt like I had to be very careful replacing the cover on the TEC, not so much on the SVX. My friend agreed. The SVX dew shield felt more secure and substantial.
So far, it’s sixes - we both preferred the SVX’s “business end” and the TEC’s focuser end. Overall quality was outstanding and basically indistinguishable. Off to the observing races…..
The moon. We took turns on each other’s scopes, unfiltered. I started with the Delite 7, she the Delite 3. The views were nearly identical in the 7, both being beautifully sharp, color free and with absolutely outstanding contrast. I thought the TEC was just a little bit warmer, the SVX whiter and more clinical, for lack of a better term. The 3 showed the same, though the TEC seemed a little less warm than it did with the 7. I was looking at a well-defined demarcation of sunlight at the very tip of a ridge near the terminator, and it was the best view of the moon I’d ever seen, in both scopes. Simply spectacular. No objective difference whatsoever, no pun intended, we both agreed. I doubt I would have noticed the warmth of the TEC’s view had they not been 10 feet from one another.
For grins and context, we tried the N31T5. Sharp as a tack in both, the sky was black, no color, fields were both basically flat to the edge. Again, no preference.
Our final moon views were with a 9mm Optimus. There’s nothing quite like seeing the entire disk of the moon at ~100x. The TEC’s warmth was evident. The SVX, maybe because of the lack of warmth, looked a little sharper.
Moon champ - a tossup.
We moved on to Albireo using the Delite 4MM. This showed a bit of a difference, with the SVX being slightly, but noticeably, brighter. The sharpness, color and contrast was the same in both scopes. Using the 2X Barlow, the SVX brightness advantage was less pronounced. Both scopes showed a nearly perfect image at 450X, give or take. Inky black sky with a blue/white and yellow double. Some nudging to keep up, which, as an aside, both mounts handled beautifully.
Winner - SVX by a nose due to perceived brightness.
Good time for an amateur star test using nearby Anser and the Delite 4. Simply put, not any difference that I could detect, with seeing probably 9/10. She thought the same. We weren’t that scientific about it, basically just defocusing in and out until the disk filled roughly 20% of the field. Both looked pretty textbook, no aberrations. She thought the TEC showed a barely perceptible darkening presenting as a thin outer diffraction ring, but I couldn’t see it. Both snapped through the on-focus position in the same manner.
Winner - tossup. I think.
Off to M13. Of the handful of objects we observed, M13 showed the greatest difference between the scopes, to me anyway. We tried the Optimus 9 and the Delite 7 & 4. The 9 obviously showed more context due to the wider AFOV but while the SVX again was a bit brighter, the TEC made M13 look, I dunno …. somehow better. I can’t even explain what that means, other than it was more pleasing to my eye. My friend couldn’t see any difference aside from the aforementioned “clinical” SVX view. Maybe that was the answer; I may prefer a warmer view of globulars. Switching to the 7 did nothing to dissuade me - TEC still looked “better” even while filling more of the field. Both scopes hinted at core resolution through the 4, very nice.
M92 was nearby, and impressions were the same as with M13, though there wasn’t quite as much difference between the scopes.
Winner - TEC by a head.
M57 was next. I hate that #@%!  I think the roots of my anti-Ring pathology dates back to when I used to try (and mostly fail) to find it by star hopping in a narrow, F10 SCT. It did, however, look very nice, sharp and identical in both scopes through the Delite 3. I tried the Barlow with the 3, probably just out of Ring spite, and it flew through the field so fast that I became all p!$sed off at it again. Just like old times. I’ll admit, the little ba$!#rd looked great while doing so.
Winner - nobody wins with M57.
On to Caldwell 14. It is a sight to behold through the 9. Interestingly, the TEC showed FZ Persei as slightly redder, closer to the view through our 10” LX50. The SVX showed more orange. Again, it was a very slight difference, and my friend’s comment was “eh, maybe”. So “eh, maybe” it shall be. I chalk it up to the “clinical” thing with the SVX. Both were equally sharp with equal contrast. Thinking about it, the SVX reminds me a bit of an AP I looked through last summer, so color-free it looks like an expertly taken black-and-white photo.
Winner - TEC by a whisker due to the color of FZ Persei.
The last DSO we compared was M31 with the 31T5 after the moon set and well, wow. I love looking at that object through that EP, and it looked every bit as spectacular in the TEC. However, I have to say that unlike M13, I slightly preferred the SVX view this time, but only slightly so. It felt “fuller” to me. Her response was “oh yeah, it looks a little better.” Not enough to matter, really, just … a bit different.
Winner - SVX by a nose. Doesn’t make a lot of sense, but we both saw it.
We looked at Saturn once the moon set and it was higher in the sky. Unlike the rest of our targets, I could detect zero difference. We used the 7, 4 and 3 Delites and Barlowed the 4. Both scopes showed the planet, surface banding, 5 little twinkling moons, the rings and the gap perfectly. I have to say that though my brain knows I can see “more” of Saturn through my 10” SCT I much prefer the refractor view, even at 55% of the aperture. Simply stunning.
Winner - none.
The finale was an N31T5 sweep of the area between Scorpius and Sagittarius. Frankly it’s such a rich star field that it’s probably impossible to detect any difference between the scopes, and neither of us did. You get so wrapped up in the diamonds, and the velvet, and the occasional little ghostly nebulous wisp that any scientific purpose flies out the window. It was a fitting end to the evening.
Winner - none.
So, the payoff - which is better? Neither is perfect, and both are spectacular. The views are equally impressive. Had I not used them almost simultaneously I doubt I could tell the difference. Side by side, I preferred the SVX on some things and the TEC on others. I have to say that it’s quite possible the differences I observed were due to changes in seeing, eye position, clouds, dusty optics, the High West Double Rye, or a handful of other things. Maybe real, maybe not. They were very, very close.
The TEC, being somewhat lighter, has an ergonomic advantage and better finishing on the focuser end. The SVX has a simpler objective cover and a more robust dew shield. Basically they’re equals in nearly every sense, especially in the all-important viewing category.
I came away thinking I would have been perfectly happy with the TEC had the SVX not been available. My friend thought the converse was true. If they were sitting next to one another and some generous soul said “pick one” I’d probably pick the TEC for its handling advantage and slightly warmer views. But, and it’s a big but, if that person added “and pay for it and wait for it” to their offer I’d have to ask is it worth several hundred bucks more (fully equipped), and is it worth waiting 18 months beyond the SVX? I don’t think it is, but your mileage may vary.
This kind of comparison is probably a little silly with two world-class scopes. Nothing credible that I have read or heard lead me to think there would be any meaningful difference. There was, maybe, a little bit of each of us coveting what we don’t have, but nothing serious. We both agreed that it’s nice to be able to eliminate any lingering doubt one might have about his or her choices. We certainly accomplished that, and had a great night of observing to boot.
Cheers.
  • Catapoman, Scott Beith, rustynpp and 55 others like this
#2 weis14
weis14
  • Loc: Midland, MI
Posted 07 July 2022 - 09:34 PM
This is a great head to head comparison and it sounds like you had a wonderful night of observing.  I had no doubts that both scopes would put up wonderful views.  Thanks for sharing!
  • T1R2 and Bkmiller4463 like this
#3 Mike Sandy
Mike Sandy
  • Loc: SF Bay Area, CA
Posted 07 July 2022 - 09:53 PM
Thanks for your efforts and write up!  Absolutely enjoyed your comparison.
#4 betacygni
betacygni
Posted 07 July 2022 - 10:34 PM
Thanks for taking the time to do this comparison and write it up for us. Very interesting read. I’m sure it will be helpful for many.
  • Bkmiller4463 likes this
#5 turtle86
turtle86
    Mr. Coffee
  • Loc: Margaritaville
Posted 07 July 2022 - 10:40 PM
Great read!  Thanks for sharing!
#6 BRCoz
BRCoz
  • Loc: San Tan Valley, Az
Posted 07 July 2022 - 11:34 PM
Torrey is a nice place to do some viewing.  Nice report, sounds like a win win.
#7 idclimber
idclimber
  • Loc: McCall Idaho
Posted 08 July 2022 - 12:13 AM
I almost ordered the SVX140, I instead went with the SVX152 and should have it in the next couple weeks.
  • Scott Beith, tboss70, cahanc and 3 others like this
#8 tboss70
tboss70
  • Loc: Missouri
Posted 08 July 2022 - 07:03 AM
Nice report, thank you for taking the time to write it up and share it.
#9 Trader_Vix
Trader_Vix
Posted 08 July 2022 - 07:48 AM
Great report, helps with my own experience and context with my recently acquired SVX140 since I don't have another scope of that calibre to compare mine to. Maybe I ought to fire up the Meade 127ED one more time before listing it on classified just to do a similar comparison for my own curiosity sake...but sometimes the expression (nothing good can come of that) comes to mind smirk.gif ...we shall see..btw...I luv M57!
Oh..one last point..I don't seem to have an issue with the weight, I am not really going to move mine around much and it compares with what I was dealing with my 127ED...however I do agree on the 2" collet with the 3 screws...seems chincy and all three screws can't really lock up..my Meade uses just 2 (larger) nylon thumb screws and I like that one better....yes, I already tried to switch the collets...thread is different.
tv
Edited by Trader_Vix, 08 July 2022 - 07:56 AM.
#10 bikerdib
bikerdib
  • Loc: Southeast Texas
Posted 08 July 2022 - 08:50 AM
As others have said, nice work/play comparing the 2 two.  I have really enjoyed my 152SVX even though I have larger scopes, there is nothing that compares to the view through a very good refractor
  • Scott Beith, AstroCub and Bkmiller4463 like this
#11 KTAZ
KTAZ
  • Loc: Scottsdale, AZ
Posted 08 July 2022 - 10:18 AM
Thank you for this extensive and objective review. It is precisely what we need to help change the opinion of folks that simply refuse to give Stellarvue the respect it deserves. They produce a fine scope and their optics now rival those of both TAK and TEC.
Old opinions die hard, but the more factual information presented, the better.
  • Max Lattanzi, T1R2, 7Soeurs and 2 others like this
#12 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 11:30 AM
Thanks Vix. I asked Isaac at SV about the focuser awhile back. He said they use the standard FT collet, but suggested I try a clicklock or others that I can’t remember right now. It’s usable, but like you, I don’t think all 3 screws are working together.
Speaking of screws being loose, tell me about your affection for M57. grin.gif
tv
Edited by Bkmiller4463, 08 July 2022 - 11:51 AM.
#13 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 11:40 AM
You’re welcome! The optics certainly looked every bit as good as the TEC, maybe even a little brighter. I have quibbles with the mechanical things I mentioned, but so did the TEC owner with her scope.
I like TEC a lot, even moreso since one of their people pointed me toward SV saying the optics were “as good as TEC and AP”. As far as old opinions, bingo. When I was looking for advice on CN a year ago it was pretty obvious to me (and probably everybody else), who had informed opinions, good and bad, and who had an old rusty axe to grind.
Edited by Bkmiller4463, 08 July 2022 - 11:58 AM.
  • Spikey131 likes this
#14 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 11:42 AM
Thanks! I’ll have to look through a 152 one of these days. I’m curious if I could see the difference.
  • Bobby Astro likes this
#15 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 11:44 AM
I assume you’re aware of the strict CN rules covering unboxing photos and commentary, and a subsequent first-light report. Looking forward to reading about it (and seeing the photos, of course)!
  • KTAZ and Howard_C like this
#16 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 02:33 PM
You’re welcome. It was fun, not to mention educational.
  • 7Soeurs likes this
#17 peleuba
peleuba
    Non-Metrologist
Posted 08 July 2022 - 02:34 PM
Thank you for taking the time to do this.   I found the differences you highlighted to be meaningful and interesting to me as the reader.  And, it shows you paid attention to the details.  I've always found comparing telescopes at this high level to be an exercise in subtlety and it sounds like you'll agree.  Both scopes share more in common then their differentiators - both are ED triplets.  I don't have a good explanation for the differences other then the oil spacing vs. air spacing.  Air spacing does allow for a higher level of correction when designing a lens.  It sounds like each lens is well figured.
Did you get any photos of the two scopes side-by-side?  I'd like to see a money shot of each lens and compare the multi-coatings.  From previous ownership, I know the TEC coating to be top notch.
Edited by peleuba, 08 July 2022 - 02:47 PM.
  • Scott Beith, Jeff B, payner and 2 others like this
#18 kvastronomer
kvastronomer
Posted 08 July 2022 - 02:37 PM
What is waiting time for SVX152 these days?
#19 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 03:02 PM
You’re welcome. I hadn’t thought of oil vs air, but that could be it. I’m leaning toward the High West Double Rye as the cause. tongue2.gif
No photos, and frankly I was kicking myself Wednesday morning for not thinking of that. I’m not sure I could recognize one coating vs the other. To me the SVX looks a bit green, but I can’t say I really looked at the TEC.
I got a kick out of your other post about hype in this hobby. I like watches and cars, and man, if you want to see hype beyond anything Vic or Roland or anyone else is capable of, check out, especially, the high-end watch hobby. I also don’t understand your disbelief at the optics being done at the SV facility, but I don’t need to understand it I suppose. I sort of understand the marketing hype “sting” you mentioned but I don’t get why it seems to linger so much longer in this hobby.
Edited by Bkmiller4463, 08 July 2022 - 03:16 PM.
#20 Jon_Doh
Jon_Doh
  • Loc: Just South of Pluto
Posted 08 July 2022 - 03:48 PM
Thanks for the comparison and report.  If I lived in your neck of the woods I would have offered to toss my 140 doublet in the mix to really compare oranges to tangerines.  FWIW, M57 looks superb in my 140.  I have a tracking mount and it keeps it in the eyepiece.
#21 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 04:09 PM
  • Jon_Doh likes this
#22 JimP
JimP
  • Loc: USA
Posted 08 July 2022 - 05:25 PM
Thank you very much for your comparison. Based on your very detailed report I wouldn’t think anyone would be dissatisfied with either scope. I have a TEC 140 ED, a Berlebach Planet and a Berlebach UNI 18 which just arrived. The uni 18 has a peanut brown stain and looks very nice as does the planet as well. Do you think a Uni 18 is enough to hold a TEC 140 or do you think the 140 ED needs the planet for adequate stability?
using a DM-6.
I’ve owned lots of refractors . I just received an SVX102D which, of course, is a doublet. It performs beautifully!
best,
JimP
Edited by JimP, 08 July 2022 - 05:41 PM.
  • Scott Beith, Jeff B, Space_Race_T.J. and 1 other like this
#23 idclimber
idclimber
  • Loc: McCall Idaho
Posted 08 July 2022 - 05:46 PM
I am not sure unboxing photos are really my style. smile.gif     Plus I doubt anyone is really interested? I do plan on uploading some subs definitely from my 2600 with both the reducer and the flattener. At some point the same with my full frame D850 unless I break down and simply order the 6200mm. although Its not the camera, it the full set of 2" Chromas that has me paused for now.
The appeal to full frame is that I could get really close to the same FOV with the 152 at f/6 as have with my 102 at f/5.25. Which might mean selling that scope if I was happy with the quality. My D850 has only slight larger pixels than the 6200 at 4.35um, so testing it would definitely be worth my time.
When I talked to Vic he stated they had a longer wait for the SVX140 than the 152. This was a couple weeks ago. I was next inline if I ordered the 152 and the main delay would be how long it would take to get my Moonlight focuser in. I wanted it as Imaging is really what I am interested doing with this scope. I have not used any of my eyepieces for a couple years. He guessed 4 to 8 weeks.
He said there were several people waiting on the 140 and it would be a couple months if I ordered that model.
  • lionel and Bkmiller4463 like this
#24 Bkmiller4463
Bkmiller4463
Posted 08 July 2022 - 06:32 PM
You're welcome Jim! I haven't used a Uni, but I think the Planet is more than enough for the 140. I would certainly try it - if it performs as well as the Planet with the 140, it's signficantly less weight to carry. Let us know.
using a DM-6.
best,
JimP
Edited by Bkmiller4463, 08 July 2022 - 07:33 PM.
#25 bikerdib
bikerdib
Posted 08 July 2022 - 08:42 PM
I want to add something about the 3 screw set up.  I've had this set up on several previous scopes as well as my current SVX and I find it to be workable and very secure.  Something I find that helps the set up work best is to look inside where the inner metal band is that protects eyepieces from screw marks.  There is a gap in the band, make sure one screw is centered directly across from the gap and mark that screw (if needed, push on one end of the band and rotate it around to make one screw directly opposite the gap).  That screw is the one you tighten first then proceed tightening the other two.
If you tighten the two near the gap first then try to tighten the one opposite the gap it isn't able to push the ring gap together as needed.  I hope that makes sense to you.
  • Scott Beith, Dan Finnerty and AstroCub like this
