Hey all.
Like probably most HEQ5 owners, I thought my mount was a little stiff (although smooth) in dec and in RA. And like probably most HEQ5 owners, I went to YouTube to become an instant pro on ripping stuff open.
So, this led me through a number of videos some good, some less so, but probably the most useful is the one by Astrobloke that I know most of us have seen. But he's clearly starting with a used mount of unknown past. So he starts with the rather aggressive approach of replacing all the bearings. with new, and comments along the way that at least a few of the bearings in his unit are a little notchy and probably were never very good.
At the end of his video (and other videos from other people do the same) he gives the RA a spin and it goes like a top, obviously moving a lot better.
But what I had some difficulty believing was that the bearings were the cause of all that original stiffness. And since he's recommending buying about $200usd worth of bearings I thought I might take a more pragmatic approach.
My mount is pretty new, and I am its original owner. So I have no reason to believe the bearings are all chowdered up.
So I dug in without ordering parts just to do a little exploratory surgery following Astrobloke's instructions. Here is what I discovered..
1) The bearings are name brand JESA (a Swiss brand of reasonable pedigree, not some cheapo junk).
2) The bearings were all free and smooth.
3) There was some excess grease here and there, but not too bad. I did clean it up a bit.
So what keeps your RA from spinning like a top on your HEQ5? Its all over tightened. Notice that when youtubers disassemble their mounts, they need the occasional tool to get the stays to break loose, but when they reassemble they go hand tight no tools. Why don't any of them bother to point out that this is 90% of the problem? Its not like they have affiliate links to bearing shops, so seriously it seems like a weird omission. New bearings are not necessarily the magic bullet.
Another hang-up on the RA could be the green RA marking ring. If you have that fastened in place, it has quite a lot of friction with the other moving parts (which in proper use allows it stay oriented, so even if you're not using that ring, don't clamp it down with its little set screw, its not hurting anything if allowed to turn, and in fact allows everything to move freely).
To be 100% clear here, the main stay that is holding the bearings too tight is the one the green ring is surrounding, it has the three grub screws around the perimeter. That guy can be simply loosened, then hand snugged and then reset the grubs to hold it in place.
Digging into the dec, I found the exact same problem. In this case the one holding everything together is the assembly with the green dec ring and the counterweight extension clutch on it, this requires a fair bit of effort to undo, just undo that, and retighten to firm hand tight. All bearings are were again JESA and were exceptionally smooth and free.
That's it. If you have a reasonably new and well maintained HEQ5 there is NO reason to assume its full of bad bearings, it isn't. Its just a little over snugged.
So there you go, and of course your mileage may vary. I have no doubt that the people who tore theirs apart on youtube and installed new stuff did it because they needed new stuff. But what they didn't explain is that you probably don't need to spend that money, and you could just adjust a few things and be on your way.
I hope I saved you a couple hundred <insert your local currency here>. Also, if you haven't already -- Astrobloke's video is an excellent discussion on how to do any thing you need to do. You just might not need to do all of that.
Take care.
Edited by KurtV, 02 August 2022 - 05:04 PM.
