Hello,
i have uploaded a new version of JetsonSky in my Github : V51_01RC
https://github.com/A...illou/JETSONSKY
I have also uploaded a brand new and up to date JETSONSKY_V51_01RC_INFOS.pdf file to explain changes in JetsonSky. I recommend the reading of this file.
This version of JetsonSky now support 16 bits video reading using SER format files (JetsonSky needs now Serfile library which is in my Github; thanks to Jean-Baptiste Butet who wrote this library ; i made some small modifications for JetsonSky).
16 bits mode will allow to recover small signal and to make HDR image with only 1 image even with post treatment (8 bits HDR mode needs several captures using different exposure times).
If you want to make some tests with a SER 16 bits file, you can find one here :
https://drive.google...iew?usp=sharing
This is a RAW capture so you will have to debayer it using JetsonSky with RGGB pattern.
I did not test this version of JetsonSky with the AGX Orin. I will test it ASAP.
For Windows version : i had some serious issue with CUDA SDK V12.5 and above. I had to get back to V12.1 to solve those issues (problem with nvcc compiler; impossible to compile CUPY kernels with V12.5 or above).
Alain
Edited by easybob95, 08 December 2024 - 10:35 AM.
