Hello Hive-mind,
I need some help with my Pegasus Astro Pocket Powerbox Micro:
It was working just fine for about a week of tests. Now, however, whenever I power it down and then power it back up the hub gets reset to "Quad 12V Outputs -- OFF". (See screenshots at bottom)
I'm want to use the powerbox to route power to my new mini PC but right now I need a running PC/laptop to use Pegasus Unity Platform to turn on the 12V power outlets.
It is set to turn on the hub at start-up and the "Adj out" does have power (and I think the dew heaters are getting power - they are set to Auto). Only the Quad Power keeps resetting to "OFF". I'm using a VATID portable power station as my power source.
Is there someway to reset the default to start with power "ON" or is this a hardware issue and I need a replacement?
Any help appreciated.
