I've saw it and no issue at all nothing is broken but the focuser which can with it has a shiny finish inside maybe this could be the reason
Internal reflections can indeed introduce multiple or ghost images.
Now, if you say everything was fine before, and you are using the same accessories, then something has changed on the inside.
Like others here, I recommend simply taking the objective cell off of the front of the tube and just look inside the tube and at the objective's front and back. Use a strong light. Maybe an internal baffle (if it has one) has shifted or maybe even spider webs (which can play the devil with images), or anything that might look unusual.
But before anything, using paper, a compass, and scissors, cut a mask the size of the lens with a 25 to 30mm hole in the middle, place it over the front of the objective and have a look. Any different?
Jeff
Edited by Jeff B, 06 August 2022 - 10:28 AM.
