Hello,
I think it's a distance problem right? what t2 adapter do you think I need?
Btw I use a 5x barlow. Both eyepiece and barlow are Explore Scientific.
Thank you.
Edited by caballerodiez91, 05 August 2022 - 11:10 PM.
Posted 05 August 2022 - 11:29 PM
Is there something on top of the focuser? Then the barlow, then the eyepiece.
It appears you are running out of in focus.
Can the first piece be removed, and the barlow fitted directly into the visual back ???
Posted 05 August 2022 - 11:31 PM
Posted 06 August 2022 - 12:04 AM
You're using both eyepiece adapters in that SW newtonian with a 1.25 inch eyepiece .... is that a commonly used configuration to reach focus ? In my 150 @5 w/ 2 inch focuser , I usually only use 1 .
Posted 06 August 2022 - 06:24 AM
Key is best is up to 50 power per inch would be best view. Your 6 inch is up to 300 power! Around 180 to 200 power would be good for most night then if view look good then try go little higher power! Very high power wouldn’t give you any details or sharp view!
Edited by Illinois, 06 August 2022 - 06:25 AM.
Posted 06 August 2022 - 10:43 AM
Power corrupts
Posted 06 August 2022 - 03:52 PM
Power corrupts
I think the full quote is...
"Absolute power corrupts, absolutely."
I think using a 3mm EP with a 5X Barlow, we can assume the power is absolute.
Edited by MarkMittlesteadt, 06 August 2022 - 03:53 PM.
Posted 06 August 2022 - 05:31 PM
Power corrupts
Absolutely.
Posted 06 August 2022 - 06:19 PM
the 3mm by itself is pushing the limits of that scope.Well, if that's a 6" f/5 newtonian, and you're using both a 5x barlow and a 3mm eyepiece, you're trying to observe at 1,250x... That might explain why you can't see anything!
Clear Skies!
Thomas, Denmark
Posted 06 August 2022 - 06:59 PM
Edited by Chad7531, 06 August 2022 - 08:20 PM.
Posted 06 August 2022 - 09:17 PM
Posted 09 August 2022 - 11:48 AM
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
