Yep, interestingly enough, it does!
Just had it out for the first clear evening in weeks (AZ monsoon season, ugh) to do a quick visual star test for collimation. Sure enough, it needs to be tweaked a bit after shipping.
However, when turning the focus knob counterclockwise, I get an audible metallic "singing" coming from the mirror sled. Focus is smooth, but the CCW movement is just slightly stiffer. I don't expect that this is any issue at all; the Edge units do have tighter tolerances between the mirror and the baffle, so I expect it will "shut up" once enough lube distributes along the baffle tube.
I just found it interesting and though I'd ask if anybody else experienced this.
