Thank you, Dave.
Are there any downsides to not fully illuminating the chip? I have a ZWO 2600MC which I use with my refractors but if the only downside is vignetting I am okay with that for now.
I have an 8" F/5 that when using a planetary camera (224 or 462), it does not come to focus without a Barlow, which, I never really use without one. When I have used the 2600MC with it, it came to focus without the Barlow. I would like to think the same would happen with this F/6 if configured correctly and ensure the focus tube does not interfere with the light path when taking pictures.
Just out of curiosity, how does one visualize the light path on the chip? How would I know the coverage of light on a 1.52" vs 1.83" vs 2.14" secondary mirror?
In reading the link you sent, it sounds like "A telescope which is optimized for photographic use does not usually perform well for visual work."
But how well can a telescope optimized for visual, work for astrophotography? I think this goes back to 'what is the downside of not illuminating the chip 100%". Again if its just smaller field of view, vignetting, and some cropping, I may be okay with that since I'm not looking for wide field images.
"Photographic Use:
Generally, to attain the brightest image (and utilize the full potential of the telescope's light gathering ability), the film in the camera should be as fully illuminated as possible. This requires a substantially larger diagonal mirror than does visual work.
In a 35mm camera, the short dimension of the film is 24mm (about 1 inch). The camera body requires the focal plane to be moved farther out from the focuser as well. Adding 2 inches of focal plane height for the camera body, and requiring a 1 inch area of 100% illumination will call for a fairly large diagonal mirror.
The other components of the telescope must be redesigned to accommodate photographic work. The focuser inside diameter must be larger to prevent vignetting of the light cone, and the diagonal mirror spider mount must be strong enough to prevent the heavier mirror from vibrating or sagging.
