Newton rings: Solved
No replies to this topic
#1 Helen P
Helen P
Posted 10 August 2022 - 02:48 AM
Hello,
I had a quite severe case of Newton rings with my setup: Lunt 50 + ZWO 120mm
Using a tilt adaptor, setting the possible tilt to maximum this has now been easily fixed. Attached two photographs before and after applying the tilt. Sadly these are from different dates. I took photos before and after applying tilt on the same day, but it seems Asicap managed to overwrite the first series of files between camera decouplings (to set tilt).
