Secondary support for heavy telephoto lens
6 replies to this topic
#1 sumitshrestha
sumitshrestha
Posted 13 August 2022 - 03:48 PM
I have nikon af-s 300mm 2.8 and flat dovetail. I can attach it to the dovetail using single screw. I am thinking of adding secondary support at front of lens. What would be better options for me? 3D printing a ring or buying off the shelf telescope ring? I am really confused as to what I should do. IMG_9170.jpg IMG_9167.jpg
#2 MitchAlsup
MitchAlsup
Posted 13 August 2022 - 06:01 PM
For your purposed, wood would be good.
#3 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 13 August 2022 - 08:35 PM
Yes, you definitely need not only to support the lens, but you need a method to keep the lens from yawing to the left or right as the lens is oriented towards different parts of the sky. A single-point threaded connection can be torqued loose by the weight of the lens.
The method of support will depend on where the support touches the lens. If the support touches a rotating part of the lens, you might need a rotating ring, a V block with roller contacts, or a V block made from a low-friction plastic like delrin.
If the support touches a non-rotating part of the lens, then almost any simple V block could be used.
If you use a V block, a stiff bungee cord could then be used hold the lens against the block.
  • sumitshrestha likes this
#4 sumitshrestha
sumitshrestha
Posted 14 August 2022 - 12:02 PM
Any specific wood designs that comes to your mind? I am not a carpenter or have done any wood work in past so totally new to this. Thanks for suggestion.
#5 sumitshrestha
sumitshrestha
Posted 14 August 2022 - 12:34 PM
 Yellow line is rotating part and light blue is non rotating part. So basically front section does not rotates and has huge ed objective lens. So a support there would be perfect. I was just wondering what kind of support design would work best. I was thinking of using some kind of cord but was worried it might slip under extra pressure. I am fine with investing some money on decent support as long as it gives me peace of mind. Thanks.
#6 Jaylab
Jaylab
Posted 14 August 2022 - 12:59 PM
I often use this same lens and have never found it to need support with time exposures. This stock lens foot is prone to resonance at shutter speeds from 1/100th to 1/4 second but I have never encountered a problem with longer times.
If you still wanted to support the front I would suggest a tapered wood wedge between the region just to the left of your white line and the aluminum foot.
-Jay-
#7 MitchAlsup
MitchAlsup
Posted 14 August 2022 - 04:24 PM
Prior to the Russian invasion I would have suggested Baltic Birch. Strong, light, out-door grade, beautiful, not-that-expensive, easy to work with standard tools.
Also note: with respect to the picture of the lens, there is no <known> reason the holder could not be on the light shroud (forward of the blue non rotating ring.)
