This is a fairly long post but I thought I'd add some of what I actually see as compared to just listing object designations. Mind you I don't have a clue how accurate I was. In the past I've gone back to targets and realized I was in the wrong spot. It happens.
March 4th
4” Televue refractor with NVD
Manual tripod with digital setting circles.
Tonight was one of those nights where it started off clear only to quickly cloud up. Shortly after setting up my tripod, I pulled it back down as the sky became solid overcast. Never even got the chance to set the scope on the mount. But I was able to catch a few cell phone shots of Jupiter and Venus before they were obscured by clouds.
I then retired into the house a bit disappointed. After making some coffee, I came back out to find it somewhat clear. So back out I went and set everything back up again. Glad I did. With large breaks in the cloud cover I was able to navigate around without too many issues.
I revisited most of what I did a few nights ago. About the only change was a more intense moon. The seeing was maybe 2/5 and about the same with the transparency but over the evening both improved a little. Unfortunately, sometimes I was pushed around when clouds would move in. These things were developing and moving faster than normal and seem to come out of nowhere. At least they didn’t hang and usually moved out about as fast as they had evolved. Like a few days ago, I was mainly after open clusters but planned to possibly see what the NVD could do on a few galaxies. I knew the moons effect would cut down on how apparent the targets would resolve but it would be a good test of my PVS-14. I’ve been totally impressed with my new NVD over my old Collins i3.
Being I was delayed for a couple hours due to clouds, I had to skip several after-dusk targets. It was a look into the near future. I do miss the winter constellations and objects as spring rolls around. My light polluted backyard doesn’t do galaxies very well.
Starting out, I spied on the Orion nebula for a few minutes and the trapezium was easy as usual…even with the somewhat poor seeing. Cassiopeia was getting low and most of her targets has drifted below my line of sight. Even Andromeda was too low.
I jumped to Perseus and started off with M-34. This was a fine cluster tonight even with the moon and I counted close to 60 stars in the main group.
I decided to check out NGC-1502 in Camelopardalis. I could see about 35 stars in the main group and of course I followed the line of stars known as Kemble’s Cascade that flows in or out of NGC-1502 depending on your preference. Scanning the chain of stars was interesting with the NV unit.
Back to Perseus I checked out NGC-957 which looked to be a loose scattering of stars. Its main feature I could see was a line of stars that form a point. The bottom line of stars (away from the point) had a dense and almost washed-out group of stars that would probably have more impact if the moon wasn’t present.
On to the Double Cluster. Hard to pick which one is the better of the two but I kind of lean toward 869 as my favorite…at least during this session.
Next up was NGC-1220. I had a hard time with this one. I know there is a small dim grouping of stars here but they were unresolvable tonight.
NGC-1245 wasn’t much different. All I could make out was a small group of about 6-7 stars situated closer to the two brighter stars of a larger 5-point star asterism. Perhaps I was off target but I didn’t take time to verify anything. Just went to the next object on the list.
Before it got too late, I decided to skip over to Taurus hoping most of its objects had not dropped out of sight. NGC-1647 is a very nice large grouping of stars. Even in my 14mm EP, it was larger than the FOV. I counted about 5 brighter stars (two of which dominate) in the main group intermixed with about 60 dim companions.
NGC-1746 was another nice group. Overall, it was a wide group but there was a smaller conspicuous line of stars within the group of about 60 other upper-magnitude stars. The “L” shaped line of stars stood out sharply and had quite a few others companions around it, while the rest of the group was a bit more scattered. Still, it was a nice target.
NGC-1807 and NGC-1817 are right next to each other. 1817 showed as a horizontal group of about 28 stars. NGC-1807 is similar to 1817 and showed a curved swath of about 25 stars. Both groups fit nicely in the FOV of my 14mm EP.
Orion was moving out of view so I decided to hit as much of Canis Major as I could. NGC-2345 is a conspicuous “V” shaped pattern of about 7 brighter stars that are fairly isolated making it an obvious target. I counted an additional 25 scattered stars in the area but the “V” shape asterism is what stood out.
NGC-2354 was situated right in the middle of the power pole and the big old transformer in front of my house blocking my lower views of the southern sky.
But NGC-2362 was very impressive even though the pole, the power lines, and the transformer were making it difficult. I need to be viewing these clusters about an hour earlier when the constellation is clear of that lousy pole. But 2362 didn’t disappoint, and was showing at least 35 stars a dense group surrounding a brighter star in the cluster. Away from the power line, it might have been more brilliant.
I returned to NGC-2354 but the lines were still partially blocking the view yet this time I counted at least 13-14 visible stars even with the man-made mogul blocking most of it.
NGC-2367 appeared as a scattered group of about 20 stars but a small triangle or rhombus of stars seemed to stand out. It was small using my 14mm and would have probably been best with a bit more power. As the night continued, it seemed everything was sped up and several of the better open clusters in Canis Major had drifted out of view.
At least NGC-2383 was still visible and showed about 25 stars of mixed magnitudes. It was a wide cluster. An additional 30 stars were counted as a loosely scattered group in the total field of view. Not a bad cluster.
The last target in Canis Major was M-41. This was a wonderful open cluster tonight even with the moonglow. At least 70 stars were counted in the main group. I’d venture to say it’s the best open cluster in Canis Major and arguably one of the better open clusters in the night sky.
Puppis was now close to due south at 2120 hours, and besides the power lines, it was the best time to view this area. Messier 46 didn’t disappoint. This was a fine-grained group of about 80 dim stars visible this night. There is a planetary involved with this cluster but I haven’t had much luck on small planetary nebulae (that are more stellar-like) when using a NVD.
As cool as M-46 was, I moved on to another open cluster, M-93 which was also a fine target. It was a smaller group and could have been best framed in my 10mm EP but was fine in the 14mm. Two brighter stars dominated the cluster but in the 14mm EP, it was a fairly compact isolated group of around 60 stars in FOV of the EP.
NGC-2414 was just the opposite and difficult. More of a wide group of 35 scattered stars in mixed magnitudes. But one very small dense area of stars around a brighter single star was just on the edge of visibility. My guess was this small group was the actual designated target, however it just didn’t stand out much tonight. Then came the clouds again but thankfully they left as quickly as they arrived and I didn’t have to dodge any.
Back to my list, NGC-2451 was next but very low on the southern horizon and I found the city’s light-dome was about as disrupting as the moonlight. Still 2451 was a good bright object with 26 somewhat spaced-out stars in an isolated area. The fact it was isolated was probably the coolest factor of this group IMO.
NGC-2467 was another group that was obliterated by the power lines and again clouds had moved back in causing havoc.
Viewing between the clouds, I moved on to NGC-2479. I found this open cluster appeared as a small wide grouping of 30+ stars visible through the thin cloud cover. As the cloud cover increased, the scope sat idle and I elected to grab a few pics of the sky again. After that, with the temps dropping, I decided to go in for a cup of espresso. Now armed with a full cup of high amp coffee, I came out to take a survey of the cloud cover. Wow, they had quickly moved out and the sky had mostly cleared.
Back in action, I resumed my target quest and centered NGC 2489. This cluster was really low from my vantage point and I wasn’t sure if it was washed out or I was off target. All I could resolve was a small arched group of 3 or 4 stars. Perhaps it was a combination of being in the light dome, the low position on the horizon, and the moon glow but I didn’t find what I was looking for. It’s funny because sometimes if I slew away and then back, the cluster might just pop into view. Not this time, so I moved on.
NGC-2539 was a nice group. It was a fairly isolated group of +/- 50 stars with a brighter local member on the perimeter of the group. I liked this cluster.
The last one on the Puppis list was NGC-2579 and of course again the power pole made it impossible to view. Just poor timing on my part. As the sky cleared, the wind kicked up making the espresso a welcomed drink. At least my backyard is highly sheltered from wind and it’s usually not an issue except in very high winds. I did have to put on a heavier jacket though.
I finally made it to one of my favorite late winter constellations… Monoceros. I would quickly find that I was running this constellation a bit late, and many of the selected targets were crashing into my neighbor’s roof. But at least M-50 was in view and I’ve always felt it was a fine target. A good 80+ stars were visible even with all the moonlight and it appeared as a nicely concentrated open cluster in the EP.
There were several clusters still up and NGC-2236 was next on the list. It appeared as a wide swath stars. About 9 brighter stars stood out as a very small dim group with about 16 lesser ones in the area. Outside the group, a couple close bright stars looked to outshine anything in what I believe was the actual target.
In Monoceros, besides M-50, another keeper cluster/nebula is the Rosette Nebula complex NGC-2237 & 2244. I guess NGC-2237 is classified as the Rosette Nebula which is quite spectacular in my image intensifiers using an Ha filter. I’ve even seen it in bright moonlight but tonight I didn’t even get a filter out. I was on an open cluster hunt and NGC-2244 is the open cluster the Nebula surrounds. In full moonlight 2244 is still a fine group. It was very bright and stood out sharply. But the group showed a dimer scattering of stars above the main cluster adding to the total count of over 60 stars seen during this session.
Next was NGC-2251 which appeared as an elongated half dome group of stars. Only about 14 stars were visible with a scattering of stars outside the group. This cluster wasn’t overly impressive but was still worth a look.
NGC-2252 was baffling as it appeared I’d already seen this one. Perhaps it was memories of a few nights ago. There were +/- 17 stars visible in a slightly more concentrated group among a wider scattering of stars on the perimeter of the 14mm FOV.
Another lesser impressive cluster was NGC-2254. If I had this group zeroed in correctly, it appeared as a line of stars that formed the outline of a flat brim hat. I’ll have to revisit this one in the future because I really didn’t have a clue if I was on target.
After another round of espresso, I traveled to NGC-2259. This cluster did not stand out much. Most stars were scattered with a very limited central core area holding about 7 stars. This was another group I wasn’t sure if I was on target without looking at a star chart to confirm.
NGC-2264 on the other hand was awesome. It was a large inverted U-shaped group of about 35 stars. A brighter locally located star looked to light up a few closer stars. My list showed it as the Cone Nebula but no hint of nebulosity was observed. The 14mm was not the best EP for the cluster and I felt it could have used more magnification. The only thing I could make out was a Y shaped line of around 13 stars with a 4 or more close by. I could almost make out the word “YO” formed as an asterism.
NGC-2266 was a long way from all the previous targets and incorrectly listed as an open cluster in Monoceros but was actually in Gemini. About +/-11 stars formed a box like asterism with about 5 or so stars outside the box.
Sticking to Gemini, NGC-2304 was a totally confusing area. It seemed like a just a very wide star field. I guess it’s another one I’ll have to research.
NGC-2420 appeared as a wide more concentrated group with 5 or 6 stars in the central region. About 20 stars surround the small group.
Moving to Cancer I picked up the beehive group, M-44. I didn’t spend too much time on this bright large open cluster but it is very impressive as a wide field object.
The last target in Cancer was M-67 which had about 40 stars visible in a somewhat concentrated group using a 10mm EP.
Leo was up next. I had wondered how well the PVS-14 would show galaxies and M-65 was the first test under bright moonlight. To my surprise, a few were visible from my light polluted backyard and again the moon wasn’t helping. In my 14mm EP both M-65 and M-66 were visible at least. I felt that was pretty good despite the crappy light conditions.
But I didn’t have any luck with M-95 and M-96. M-105 showed up well though.
I moved into Coma Berenices and M-64. As I looked through the EP, I noticed an abrupt dimming of the stars in the area. I looked up to see heavy cloud cover moving in, which within a few minutes, robbed me of any more targets. The night was over just past midnight.
Despite the clouds, the night was very productive IMO.
Edited by daveb2022, 06 March 2023 - 10:08 AM.
