And then we find that 2.5x GSO being 25% off…..
20% - and not good!
But it's a good 2x barlow...
Posted 24 August 2022 - 01:12 PM
20% - and not good!
Posted 26 August 2022 - 07:12 AM
20% - and not good!
Exactly. As long as you know what you’re getting before you buy it. One of the reasons I love this place.
Posted 26 August 2022 - 08:52 AM
I love the 1.8 and 2.5x Circle NJ's i have. I don't use them much unless the seeing is near dead still.
Posted 14 April 2025 - 06:21 PM
I'm confused on this TV 3X Barlow. I figure from the letter font it's an older barlow but is it a barlow with a missing ring or a barlow before they made them with rings?
It has an indentation as where a ring would go but not ring.
Is this going to be a functional problem?
I'm thinking it it was a barlow designed without a compression ring then it should n ot have that space for one.
It means the screw will have to screw in more????
Is this going to be a problem? It has threads on the bottom for a filter if that helps date it.
Posted 14 April 2025 - 06:33 PM
Call Televue, they don't bite!
Posted 14 April 2025 - 10:05 PM
Not used to having a responsive company. I have a feeling it's an old Televue Barlow but just concerned it's not a barlow with a missing compression band.
I guess I was hoping someone with a old 3X...Hey, I'll ask Jon. Think he had one...
Posted 14 April 2025 - 10:09 PM
Oh it's old for sure.
Posted 17 April 2025 - 05:30 PM
It's a R not NJ so not the oldest & marked Japan on top of black barrel. Looks new old stock but there is a space for a compression band but no band.
Still it has a suction fit. An eye piece inserted kind of it drawn into it & tight so the screw should hold it. Seems centered.
Bigger than my Meade 2X 140 telenegative triplet modifier which I have really never used. It's so long. Do you need diagonal extenders?
I guess I'll try it on a 32mm & 24mm? would that bring it to about 11 & 8mm?
Maybe Tele Vue sells those brass bands? Wonder how they install?
space for ring
Someone said they called TeleVue & they have a end ring upgrade...Trying to find Tele Vue # or contact John Rhodes.
Edited by Universe XY, 17 April 2025 - 05:54 PM.
Posted 18 April 2025 - 04:00 AM
I have a 2x TV Barlow but not a 3x. People complain about undercuts but the real problem is the so called compression rings. As Don has pointed out, they are not compression rings, they only compress underneath the set screw,. Their main role is to protect the eyepiece barrel from nicks. The Aluminum set screw does that.
I generally remove the brass ring and just use the set screw. I have over 200 Nylon 10-32 thumbscrews. I bought a half pound of them at a surplus store. If you want one, I can put a couple in an envelope and send them to you.
My recommendation: Do not replace the brass ring. They can be problematic when used with eyepieces with undercuts.
Posted 18 April 2025 - 05:06 PM
I heard that the Powermates are better for imaging and TV Barlows better for visual. Does that sound accurate?
Pete
Posted 19 April 2025 - 09:26 AM
Pete
Posted 19 April 2025 - 10:02 AM
PowerMates solve a number of imaging problems, but they are excellent for visual use, too.I heard that the Powermates are better for imaging and TV Barlows better for visual. Does that sound accurate?
Pete
Posted Today, 01:33 AM
I get what you are saying about the ring in some. It can catch & make it difficult to insert an ep if/when the brass ring gets out of round.
Still swimming in the barlow mystery.
Really can't see using them with heavy grenade ep's.
I'm trying it just to compare but can't see regular use with such a big heavy skyscraper.
My Barlow collection is growing but mostly unused.
Orion Shorty 2X
Meade triplet 140 2X (pretty light
Dakin 2.4X very light
TV 2.5X NJ
TV 3X
Will get back when I can compare the TV's
Posted Today, 03:35 AM
Compared to Barlows, they:
--do not lengthen eye relief, so are usable with long focal length eyepieces or long eye relief eyepieces.
--do not vignette due to improper placement relative to the eyepiece
--do not change magnification with eyepieces that have different focal plane locations within the eyepieces.
--do not change magnification with increasing distance from the eyepiece (except the 5x one).
I use Barlows with medium and short focal length eyepieces. The issues that Powermates solve generally do not apply. On the other hand, the ability to increase the magnification by simply pulling the eyepiece back is rather useful.
Our mutual friend Bruce (Astro-Master) has made a science of using the 17mm and 13mm Ethos with the 2x TV Big Barlow and the A-P Barlow with spacers to achieve a wide range of magnifications. It works surprisingly well.
Posted Today, 06:10 AM
Looks to be made in the early 90's.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
