This is new behavior that I haven't seen before and don't know what is causing it.
NexStar evolution EdgeHD 8". I've had it since May 2022 and have been using it with SkyPortal on iPhone, iPad, and with CPWI on laptop with no problems, until this past week.
I start with the OTA level and pointing East. My north is blocked by trees and I've learned I get alignment with the fewest tries if I start out pointing in a direction that is not blocked.
Before this past week, it would take as few as three and as many as four tries to get a successful alignment. And if I had one successful plate solve followed by one that failed, if the next was successful I would see the counter go from 1 of 3 to 2 of 3, or 2 of 3 to 3 of 3.
Now, suddenly, it is acting differently.
I press Connect and Align. The telescope slews to a point that is not blocked by trees or buildings. Sees anywhere from 70 to one hundred stars and reports a successful plate solve. The counter goes from 0 of 3 to 1 of 3.
The telescope slews to the next position. It is pointing high at stars I can see. It reports seeing 70 to 100 stars then reports plate solve error. The counter remains at 1 of 3.
The telescope slews to the next position. It is pointing at stars I can see. It reports seeing anywhere from 70 to 100 stars then reports a successful plate solve. The counter goes from 1 of 3 to 0 of 3 then back to 1 of 3.
The next plate solve fails. Even though the telescope is pointing at stars I can see. The one after that succeeds and the counter again goes from 1 of 3 to 0 of 3 back to 1 of 3.
This happens over and over. After every successful plate solve it gets an failed plate solve. After every successful plate solve the counter goes from 1 of 3 to 0 of 3 then back to 1 of 3.
The iPhone or iPad (happens on both) both have the current time and GPS coordinates. I can see this in SkyPortal. So I checked the time, date and location on the HC. They were all way off. I didn't think it mattered, but I went through time, date and location and set them to the correct values. Then tried SkyPortal again and got the same result.
I deleted SkyPortal and reinstalled it. No difference. I did a factory reset. No difference (I did confirm that the Firmware levels after the reset were the same as before the reset).
Except for solar observing, I never use the HC. I always use SkyPortal or CPWI. But, to be thorough, I went through the alignment procedure, using StarSense Auto, with the HC. The OTA slewed to three different positions and got three successful plate solutions. Then my wife, grandson and I looked at Saturn and Jupiter.
I am at a loss as to what I am doing wrong. Has anyone else seen this behavior? If so, how did you fix it?
