FWIW, I have had consistent problems plate solving with CPWI, after several weeks of stable operation. First plate solve works, subsequent ones fail. The problem started flatter a new Starsense Autoalign calibration. Connection was serial via the port on the HC. An uninstall and reinstall of CPWI didn’t help, and the problem was replicated on a second laptop. The problem persisted after a reset of the calibration on the SSAA to default. My recollection is that the problem also occurred when CPWI was connected via my HBG with no HC connected, but I won’t swear to it, since my low speed skew issues documented in other threads were distracting me.
When I get my Evolution mount back from Celestron, presumably with the upcoming beta release of mount firmware installed that is reputed to fix the slew problem, I will verify.
Plate solving has continued to work properly from the StarSense HC used standalone, BTW. My experience with the SSAA periodically losing its alignment without any indication during sessions has relegated my use of it to mostly investigatory. This periodic “loss of mind” has happened since 2018, btw. Non StarSense alignments from the HC, such as solar system object alignments, have always worked flawlessly, and the alignment has never been lost. My WiFi has never been reliable enough to support operations from a mobile client, presumably due to congestion in my suburban neighborhood.
As I mentioned, Evolution mount, and Starsense Autoalign, not SSAG. Many revs of firmware over the years. I will report back when the mount is back in my hands, and I will be happy to capture any HBG3 communications logs at that point.
Bill
Edited by Wdh, 12 July 2024 - 09:32 AM.
