Here's my latest addition, an Orion 100ED OTA, now long discontinued. I said to myself I was going to stop acquiring scopes. I lied to myself. But it was a good price. But I still lied to myself. I'll get over it I suppose, I always do.
The scope arrived well packed, waaay over-packed actually, unfortunately costing the owner a hefty percentage of the price to ship.
The scope was in a bit of a sorry shape when it arrived. The owner had rightly and openly disclosed a haze on a portion of the objective and even sent a photo. We settled on a price and I took the risk. Once here I determined it to be a bit of condensation between the elements so I unscrewed the objective cell from the tube and placed it in a sealed tub with several desiccant packets for a couple of days. The condensation is now gone.
The focuser drawtube was very loose and would flop around a bit. Careful adjustment of the small screws made for smooth steady operation, but like all cheap R&P focusers, the draw tube would shift/rotate slightly when changing focusing direction.
Checking the collimation of the focuser draw tube with the center of the objective using my Glatter laser, showed it to be off by a good half inch or more, depending on the direction of travel for the focuser. That's almost a degree off. Not acceptable as is. The Cheshire eyepiece also showed the mis-collimation as I saw two distinct reflection dots. So I cocked, shimmed and fiddled with the focuser to make sure the laser past through the center hole of the paper objective mask, then locked everything down. It did stray from the center a bit if I racked the focuser inward, but would re-center when racking it outward, so, being fussy, I did all of my subsequent focusing going outward. Once the focuser was collimated, the Cheshire eyepiece showed the two reflection dots had merged into a single dot.
Time for DPAC testing!
Jeff
