Classic Telescopes Looking for Odds and Ends-The Ask Away Thread
1211 replies to this topic
#26 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 20 March 2022 - 07:43 AM
I say bang away about any part if i can help us or someone. I am sure i will need a hard to get part one day.
#27 marcyc
marcyc
  • Loc: Northern VA, USA
Posted 20 March 2022 - 09:25 AM
The whole point of this thread is to get or replace' that part' part needed in the restore project.In some cases like this,a lot of  discussion is needed and I think it's to the benefit of all classic restorers.We want any who need a piece to get the piece,the right piece to help them along.Discussion,involving whatever that part might be,is certainly encouraged as long as the focus remains about the part requested and sometimes(like in this case) it's certainly going to take significant discussion to find the 'right' part.
Thank you for this. If it were just going to be as simple as "I need a _____," wanted ads in the classified section would suffice. Can you imagine trying to ask for the part Guido needed there?
  • deSitter, Terra Nova, oldmanastro and 1 other like this
#28 Terra Nova
Terra Nova
Posted 20 March 2022 - 09:49 AM
The Classics Forum, Friends helping Friends. Ya gotta love it! Share the love :love:
  • PaulEK, marcyc, rcwolpert and 8 others like this
#29 CltFlyboy
CltFlyboy
  • Loc: Charlotte, NC
Posted 20 March 2022 - 10:29 AM
Agreed. This thread has taken off in such a great way and discussions like this are a part of the "finding the right bobs and bits" process. As long as we don't diverge into a full discussion outside of the scope of the thread/ask then I think this is perfectly appropriate.
  • mdowns, Terra Nova, oldmanastro and 1 other like this
#30 oldmanastro
oldmanastro
  • Loc: San Juan, Puerto Rico-US
Posted 20 March 2022 - 04:07 PM
Mod input welcome. While this is not discussing the transaction such as address etc. it is getting lengthy on details. I'm not sure where this fits into the idea of taking this outside this string.
I pulled the stud from my Sears 4454 (middle stud in picture) and it matches your 4454 exactly as well as matching the mount for the recess area in the hub fork.
It is the same length in all ways to my short stud with the reduced end diameter (top stud in picture), and the threads match. It seems you would need one of these short versions.
My short stud is the only one I have from a complete perfect (looks new) mount. I have to keep that.
My longer stud is the size I have an extra of. The threads don't match but are close and could probably be tapped over. I photographed it with a best fit position for comparing (bottom stud in picture). Worst case is you might have to cut off part of the top if too long, and dremmel a notch in the end for a screwdriver slot.  That would take the chrome off the end.  You will probably have to run a die on it to correct the threads. This could be tricky. You don't have room to run a die all the way. You would have to do as much as possible normally then reverse the die and work it on backwards which could fail. This will take some shop sense and experience to figure out. The long stud will not screw into a short stud hole without some thread mods. It looks like you could tap the hole in the RA housing tang instead. SO FAR your thread specs have not been confirmed but it looks like a mismatch for a long stud.
I think it is worth a try if you want me to send my surplus long stud. Your drive might fit over the extra length and the threads don't need much but some.
I think that the longer stud will fit as well and if not, I can cut it down to size and use my Dremel on it. The threads will be no problem. I can run the die carefully and correct for the size. This stud will be the lifesaver for using the drive motor on the 6305 mount. I will PM you. Again my thanks. This thread is doing the job it was designed to do 100%. A great thread.
  • Vesper818, DouglasPaul and norvegicus like this
#31 1939Dodge
1939Dodge
  • Loc: Danville, Pa.
Posted 21 March 2022 - 12:34 PM
I need a declination control mounting bracket for an
ATCO 1254 mount. Any help is appreciated!
  • Bomber Bob and LU1AR like this
#32 deSitter
deSitter
    Still in Old School
Posted 21 March 2022 - 03:25 PM
Is there any other missing piece? This is an ideal candidate for JBWeld. That is not really a load bearing piece.
-drl
  • Bomber Bob and neoclassicalguy like this
#33 Gil V
Gil V
Posted 21 March 2022 - 07:07 PM
I am looking for two of these circular red “Dynamax” stickers. If they are attached to the bearing cover/dec knob or loose doesn’t matter.
These will complete a Dynamax 6 and 8 for me.
Thanks in advance.
Gil
  • deSitter, Starsareus, Bomber Bob and 1 other like this
#34 oldmanastro
oldmanastro
Posted 21 March 2022 - 10:42 PM
Thanks. I’m going to find a form for the ID and mold the missing piece  with PC Metal. But I would still like to line up a replacement in case the epoxy doesn’t work.
One of the declination arms on one of my refractors equatorial mount broke at the section that connects to the slow motion control mechanism. I used JB Weld (long setting time)  on it and it has been holding firm for several years now. It doesn't look pretty but is holding.
  • deSitter, mdowns, Marc-Andre and 1 other like this
#35 deSitter
deSitter
    Still in Old School
Posted 21 March 2022 - 11:37 PM
Thanks in advance.
Gil
Someone here can surely describe how to make an exact replica. Good luck!
-drl
#36 CltFlyboy
CltFlyboy
Posted 22 March 2022 - 10:46 AM
All - let's please take conversations about fixes and uses out to other topics so we can keep this thread as closely as possible related to asking for missing hardware.
#37 semlin
semlin
Posted 24 March 2022 - 05:22 PM
so i just bought a unitron 142 at auction.  just the ota and tripod in their boxes but no mount or mount box.
if anyone has a 142 mount all alone , keep me in mind.
conversely, before i incur the cost to ship this stuff home, if anyone by any chance has a set of legs for an r73 royal astro mount and for some reason would like to own a unitron 142 tripod in the box, i'd consider some kind of swap.  there's a pretty good chance i will be adapting the unitron legs to fit the r73 mount until fate sends a unitron mount my way.
  • norvegicus likes this
#38 1939Dodge
1939Dodge
Posted 25 March 2022 - 05:02 PM
This stud threads into hubs or locknuts so the nut can be tightened without tools, by hand. Anyone know what they are called, or where I can get some? Thank you!
#39 semlin
semlin
Posted 25 March 2022 - 05:17 PM
try "machine handle" or "tapered lever handle" but they are described several ways.  mcmaster carr sells them.
you can also buy a shoulder bolt and have a machinist shape them on a lathe to suit.
  • deSitter likes this
#40 PawPaw
PawPaw
  • Loc: West Central Missouri
Posted 28 March 2022 - 09:56 AM
In need of a Unitron 128 counterweight for the threaded shaft.   Open to try any counterweight close to the following dimensions and weight:
The CW has a diameter of 2-7/8" or 73mm.  The height is 1-15/16" or 48mm.  Approx 3 lbs.
Don
#41 deSitter
deSitter
    Still in Old School
Posted 30 March 2022 - 04:51 PM
Odds and ends needed..
1. 12.5mm silver Sears HM eyepiece. Will trade same eyepiece in black.
2. Solar projection screen for single tube focuser on e.g. Sears 6344
3. Standalone illuminator with magnetic battery compartment.
4. Sun and Moon filter. FOUND
These are to complete a Sears 6344 and 6345 scope.
TIA
-drl
Edited by deSitter, 31 March 2022 - 03:11 AM.
#42 marcyc
marcyc
Posted 30 March 2022 - 05:07 PM
I have a .965 sun filter I can pop in the mail for you. PM me.
#43 1939Dodge
1939Dodge
Posted 30 March 2022 - 06:03 PM
Hi all!
I was fortunate enough to receive an ATCO 1254 that I’m refurbishing. Looking for a .965 porro prism and diagonal. Not picky about brand. Thanks for your consideration!     FOUND!
  • deSitter and DouglasPaul like this
#44 mdowns
mdowns
  • Loc: SW,FL
Posted 30 March 2022 - 08:38 PM
I believe I have a diagonal but will have to confirm tomorrow.
#45 1939Dodge
1939Dodge
Posted 30 March 2022 - 09:44 PM
Thank you all. I have located the parts, no further action necessary! Appreciate your help!
  • deSitter and CltFlyboy like this
#46 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 31 March 2022 - 08:56 AM
I'm looking for a finder bracket for my ATCO 1254.  It has three attachment screws and it mounts onto the tube.
I have asked before in the want-ads, but without a picture it's hard to describe.
It looks like this:
  • LU1AR likes this
#47 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 31 March 2022 - 08:38 PM
I could make use of a carry strap and peep site for an Astroscan to complete mine.  I finally have a really sharp one in very good shape but it didn’t come with them.
Dave
#48 norvegicus
norvegicus
  • Loc: en route
Posted 02 April 2022 - 04:48 PM
A friend who's not a CN member needs a finder scope and bracket for a Towa 339.  He has the thumbscrews that mount it.
BOTH NOW FOUND!
Edited by mdowns, 09 April 2022 - 06:18 PM.
  • LU1AR likes this
#49 norvegicus
norvegicus
  • Loc: en route
Posted 08 April 2022 - 10:56 AM
I found him a bracket that fits.  Now he needs a 6x30 finder scope.    FOUND!
#50 deSitter
deSitter
    Still in Old School
Posted 08 April 2022 - 11:04 AM
To marcyc and norvegicus - thanks for the filters! My 6345 is one step closer to complete!
-drl
  • mdowns, Marc-Andre, ErnH2O and 1 other like this
