This post and the one immediately after it:
https://www.cloudyni...help/?p=9036436
suggest that the Criterion 6000's three collimation pull-screws surround a central ball bearing that acts as the pivot point between the disk attached to the back of the second mirror and the disk attached to the center of the corrector plate. Not mentioned is whether the ball bearing is bonded to one disk or the other, or simply held captive between the two disk by the three collimation pull-screws.
So like Sean, I'd be very hesitant to remove a second collimation screw -- leaving only one screw installed. The suggestions above recommending "trial and error" using different thread sizes seem like the best advice.
I was unsuccessful finding the thread size on the web, but I did find (see page 2 of the linked PDF) that replacement Bob's Knobs are available here: http://www.bobsknobs...oldover2211.pdf If you'd consider "upgrading" to Bob's Knobs after evaluating whether or not the optical system of your Criterion 6000 are very good [*1] (as opposed to 'mediocre at best' for example), maybe an email to Bob's Knobs to inquire about the thread size and length would provide you with this information ?
(EDIT: Maybe a mistake on my part to assume the Dynamax 6 is similar to the Criterion B&L 6000 as regards the secondary mirror's collimation screws??)
Good Luck,
-- Jim
[*1] As of 8 years ago at least, CN Classic Telescopes forum participator TerryWood was using his Criterion Dynamax 6 to do some impressive planetary imagery (see: https://www.cloudyni...oday/?p=8863677 )
Edited by jkmccarthy, 14 October 2024 - 11:59 AM.
