There have been a number of postings in regarding to potential guiding issues affecting image quality. Although wire and cable management could be considered a beginning imager's issue, I have seen this discussed recently in this forum and have seen classic problem areas in some of the setups and would like to give a little back here in the way of a few tips learned many years ago with regards to wire/cable management performing long term exposures while doing film work, and as I integrated those lesson into my own recent imaging setup. Although this may not have been a direct cause of someone’s guiding issues that have been reported, we can still take simple steps to make sure this is not a problem with our setup and take it off the potential or future issues list. Everyone has a different setup and what works for me may be a little different depending on your own setup, but some of this is basic good practice whether you go portable often or in an observatory. My own setup is a hybrid, I just move it from garage to driveway for an imaging session. Some of this is just my own experience based on years in aerospace practices.
1. Consider that there are 2 distinct areas for cable management, the Upper or moveable section, and the Lower part of the mount, this will drive how you approach the best practices/integration techniques.
2. Minimize what moves (I am not against using an upper mounted power center or controllers, just make sure they are really needed and not just nice to have) especially when it comes to cables.
3. Minimize cable lengths to only slightly longer then needed, combine and use cable sheathing.
4. Cables should never run directly from any device on the Upper (OTA/guidescope/focuser, camera, controller, etc) to the ground. All upper (cables should be sheathed, secured at several places at the upper (Dovetail Areas etc.). Even lower mount cables should be secured along the (pier/tripod) etc, not draped to the ground.
5. Cable running from Upper moveable to Lower of Mount should be combined and well secured along length.
6. Use securing clamps wherever possible. Leaving any excess slack in any cable is bad, a very slight breeze just loves to screw around with excess cable lengths.
7. Make cable disconnects accessible but don’t sacrifice cable security.
8. Test as you integrate your wiring through all possible OTA movement geometries to make sure there are not areas of flopping or binding cables. I have it a little easier since I can only image east of meridian.
I have included some example pics to show how I address the above tips. I hope they may help. When I have any guiding anomalies I always review my setup, but usually it is atmosphere related more times than not.
