mouting 10micron GM2000hps on ATS 8x48" portable pier
Accessories Mount Tripod
2 replies to this topic
#1 wen_astroevo
wen_astroevo
  • Loc: Chicago/Boston
Posted 22 September 2022 - 10:49 PM
Hello,
I am preparing to mount the 10u GM2000HPS II Combi on my ATS 8x48" portable pier. The ATS now has (I think) Astro-Physcis 119FSA-FP and 119FSA adapters to accept my A-P 900GTO. I wonder what adapters are needed to mount the GM2000?
ATS makes a pier adapter for GM2000 (https://www.advanced...mmendations.php), but I think GM2000 also comes with 2 adapters --
1. 10M-2090 - 10Micron Steel Pier Adapter Flange for the 2000HPS Mounts
2. 10M-2095 - 10Micron Base Adapter Flange for the 2000HPS Mounts
I'm completely clueless and wonder if anyone might know the answer?
Any suggestions are greatly appreciated!
Clear skies,
Vincent
#2 Codbear
Codbear
  • Loc: Novato, CA
Posted Yesterday, 01:22 AM
Vincent,
I had a 10Micron AZ2000, which has the same base configuration as the GM2000 (btw I sold it because I rolled up to an AZ3000 - these are amazing mounts!).
The mount I replaced the AZ2000 with was an AP1100 that I had sold, and my pier is an 10x42 "ATS permanent pier. I remember going through the same thought process as you.
What I discovered was that the holes in the silver steel adapter plate did not line up with any of the holes in the top plate of the ATS pier.
However, as I discovered by just plain messing around, 4 holes in one of the 119 adapters you mentioned in your post ( I think it was the FSA but not sure) lined up perfectly with the 4 holes at the base of the AZ2000 mount.
I was nervous about using the standard 1/4x20 bolts that were something like 3/4" long so I ordered about 20 of the threaded bolts of varying lengths and ended up using ( I believe) bolts that were about 1 1/2" in length.
The setup worked fantastically until I sold the setup a few months ago and am waiting for my Pier-Tech 3 to arrive. Btw I sent the AZ3000 silver steel adapter plate to Pier-Tech so they could drill the appropriate holes to ensure a match!
If you have more questions, I'll do my best to remember.
Take care,
Sam
  • wen_astroevo likes this
#3 wen_astroevo
wen_astroevo
Posted Today, 02:44 PM
Hi Sam,
Thank you so much for your kind help; This is really helpful! And congratulations on your new mounts! I am so excited about getting a 10u mount.
I plan to test the GM2000 on my ATS pier as a portable setup before sending it to a future Texas observatory; so I don't fell justified buying the $4500 10Micron CENTAURUS II Tripod just to use it for a few months...
BTW have you considered the ATS pier adapter for 10micron mounts -- https://www.advanced...endations.php?
Best,
Vincent
Also tagged with one or more of these keywords: Accessories, Mount, Tripod
