SkyGuider Pro won't connect to my Asiar
7 replies to this topic
#1 GerryGoldman
GerryGoldman
Posted 23 September 2022 - 04:24 PM
Man, I feel like a rookie all over again.
This is my first star tracker, but I expected it to be fairly straightforward.
I'm a bit annoyed as I have been imaging all summer with the same equipment except I just swapped out my CEM40 for a SkyGuider Pro for my travel kit.
Today I decided to set it up and test it out.
I have connected the SGP to the AAP by the included cable (mini USB to USB).
Guide camera (ASI120MM) is connected via ST-4 cable to the mount's ST-4 jack.
All equipment, cameras, filter wheel, etc is recognized by the Asiair, but when I select the telescope icon and choose Mount as On-Camera-ST4, I get a pretty blank screen with no info showing...
I experimented with the Polar Align function and get "no mount connected error"
Am I doing something wrong or did I get a dud?
#2 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 23 September 2022 - 05:07 PM
From what I understand, the ASIAIR will only work with ZWO equipment. Since your SkyGuider  is iOptron, ASI air doesn't recognize it.
#3 bobzeq25
bobzeq25
Posted 23 September 2022 - 05:37 PM
The ASIAir will work with any ASCOM mount.  Unfortunately the SGP can't use ASCOM.
#4 GerryGoldman
GerryGoldman
Posted 23 September 2022 - 05:44 PM
Cameras, focus motors and filter wheels only.
it works fine with my iOptron CEM40 and most popular mounts.
  • bobzeq25 likes this
#5 GerryGoldman
GerryGoldman
Posted 23 September 2022 - 05:45 PM
So this isn’t really an issue. It seems to be ok with guiding.
#6 phidu
phidu
Posted 24 September 2022 - 11:38 AM
From what I have read from PHD2 you don't need ASCOM if you drive the mount through the camera ( "on camera" mode )
But if ASI Air behaves like a PC with PHD2  you must turn on the camera BEFORE the mount .
#7 GerryGoldman
GerryGoldman
Posted 24 September 2022 - 12:18 PM
Thanks. I’ll experiment further.
#8 Tom3
Tom3
Posted 24 September 2022 - 12:34 PM
Edited by Tom3, 24 September 2022 - 12:34 PM.
