Autostar II loses time and date
11 replies to this topic
#1 Zubenelgenubi2
Zubenelgenubi2
  • Loc: the Carolinas
Posted 26 September 2022 - 10:07 PM
Please help
My 10” LX-200 GPS has worked reliably for ten years but I haven’t used it in the last year or so. Tonight it can’t get the time, date, and location (GPS problem?). It says it has software version 4.29 (I think) and I’m not sure where to look for an update.
After automatic alignment, It slews to Sirius but is off by about 180 degrees (it is about a decade off in time).
Thank you,
Peter
  • Skywatchr likes this
#2 OzAndrewJ
OzAndrewJ
Posted 26 September 2022 - 10:28 PM
Gday Peter
You may have the GPS rollover bug
Start the mount and let it get a fix
( it may take up to 15 minutes to reload its almanac if it hasnt been used for a long while )
As long as you see a string of asterixes, the GPS lump is working, but cant fix.
Once fixed, press and hold mode to get to the alternate menus
Scroll to the date/time
If you have the bug, you should get the right time, but the date will be 1024 weeks ago :-)
In that case, you need to reload the firmware or turn off the GPS and enter date/time manually.
If you do reload the firmware, do not use Meades updater or its last ROM file as it is crud.
Use the freeware StarPatch loader and the 4.2g patch to get back to normal.
http://www.stargps.ca/downloads.htm
  • Skywatchr and michael8554 like this
#3 Zubenelgenubi2
Zubenelgenubi2
Posted 27 September 2022 - 11:39 AM
Ugh! I tried to update the MEADE Updater software. It used to say
LX200 GPS SMT           and then:       Welcome to            and then        Press 0 to Align
Version 4.29                                        AUTOSTAR                                   or MODE for Menu
but now it just says
LX200 GPS
©2001 Meade
and now it can't communicate with the hand controller.
#4 Zubenelgenubi2
Zubenelgenubi2
Posted 27 September 2022 - 01:09 PM
A little update:
I hit 9 9 9, and it went to
Downloading...
DO NOT POWER OFF
#5 Zubenelgenubi2
Zubenelgenubi2
Posted 27 September 2022 - 01:52 PM
Okay. Another update. I connected to a USB to Serial adapter cable rather than the serial connector on the laptop dock, and it seems to be communicating.laugh.gif
After a minute, it says it is 2% complete, so I guess I should leave it alone and see what it comes up with. smile.gif (I don't recall noticing the 2% comment earlier so maybe I killed power because I thought it froze up)undecided.gif
Peter
#6 OzAndrewJ
OzAndrewJ
Posted 27 September 2022 - 04:46 PM
Gday Peter
I did warn re that.
Did it try to load 4.2L firmware ???
If so, you have wiped out all your user data including the history
It is self healing but all your history is gone.
If you are still loading 4.2L in safeload mode, we have no idea what
the final result will be, as the rom is too big to fit in memory
and has a lot of new bugs.
You can keep recovering using safeload mode but as per before
i strongly suggest using StarPatch to load patched 4.2g
Remember, in safeload mode, only the left side rs232 port ( next to Hbx port )
works, and it only runs at 9600 baud.
#7 Zubenelgenubi2
Zubenelgenubi2
Posted 27 September 2022 - 08:59 PM
Except that the laptop fell asleep and shut down the Automatic AutoStar Updater program, it worked okay.
After telling the laptop not to sleep when plugged in, and waiting three hours to upload, it is now working.
Hooray,
Peter
#8 Zubenelgenubi2
Zubenelgenubi2
Posted 27 September 2022 - 09:04 PM
I’m not sure what history data is so losing it might not be the end of the world.
Regarding StarPatch, I’m still not sure where that fits in. Is that a loader program or is it what gets loaded?
I went to the StarPatch website and it looked like they sell a GPS unit. Since I have a working GPS, I’m not sure  what I do with them.
Thanks for your help,
Peter
#9 OzAndrewJ
OzAndrewJ
Posted 27 September 2022 - 09:48 PM
Gday Peter
If it loaded 4.2L, you have lost all your asteroids, satellites, comets, tours, landmarks
as well as all your basic setup data, name and address, site locations, PEC, SMT etc.
It is a loader program that is more robust than Meades ASU and properly checks data
before and during loading/overwriting, and allows dynamic patching of the rom files.
He sells GPS lumps that can be used on many mounts.
With Meade 497/Audiostars, he developed patches to fully integrate his lump into the firmware.
He also wrote a loader utility to load his patches .
Over time, his patch has merged into our general patches
( that fix lots of bugs and add enhancements )
and he graciously has made his loader freely available for people
who just want to load our patched firmwares.
You can do a Paypal donation on his site if you like it, but its not necessary,
the loader is fully functional, just speed limited for half the load.
#10 quigly777
quigly777
Posted 05 October 2022 - 08:36 PM
I have not used my scope in a VERY long time, Meade LX200GPS and I do have the rollover issue.  My firmware is reported as 4.2g.  Just downloaded StarPatch so that will be a project in a day or two.
#11 rmille61611
rmille61611
  • Loc: Boonsboro, Maryland
Posted 08 October 2022 - 07:29 PM
Hi there, I used starpatch about a year and half ago on my LX200 and it updated to 4.2G not 4.2g is these a difference now ? Thanks
#12 OzAndrewJ
OzAndrewJ
Posted 08 October 2022 - 07:42 PM
Gday rmille
Easiest way is to look on the StarPatch site for the patch dates
Last update for the LX200GPS was April 2019
  • Skywatchr and rmille61611 like this
