Imaging Jupiter
6 replies to this topic
#1 CharlieWSlate
CharlieWSlate
Posted 27 September 2022 - 09:05 AM
I have been unsuccessful at imaging Jupiter and am looking for any guidance.  Here is my equipment:
Celestron NexStar Evolution
6" Alt Az Mount
FL 1500mm F/10
Celestron Star Sense
Electronic Focuser
Nikon D500 (attached to telescope with a 2x convertor)
When I look at Jupiter through an eyepiece (before attaching the camera) it is very bright and even with the electronic focuser, I cannot seem to get it in clear sharp focus (it's just a bright blob).  When I attach the camera, I use live view, zoom in on the planet and try the focuser again, and not able to get a clear sharp image.  Does the size of my telescope (6") hinder this?
Any thoughts or guidance appreciated.
Thanks;
Charlie Slate
Greenville, SC
#2 slepage
slepage
  • Loc: San Diego
Posted 27 September 2022 - 09:38 AM
Hi Charlie,
The best advise is for you to do your research first, then give it a try, then post some images with some data on how you did it, then ask for help.
Start Here:  https://www.cloudyni...ated-july-2022/
Steve
  • RedLionNJ likes this
#3 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 27 September 2022 - 09:40 AM
I don't think the aperture is related to the issue you describe.  You need to set the camera's exposure down to a much shorter interval. I don't know if the Nikon synthesizes exposure during LiveView (like the Canons do) or if the exposure is a 'real' value. But you want to be in the order of milliseconds (maybe up to 30 or so).  You'll always be at a disadvantage using a DSLR for planetary imaging, as your fps will be limited (you can't set a really small ROI) by the transfer speed to your laptop.
#4 Sacred Heart
Sacred Heart
Posted 27 September 2022 - 09:42 AM
Planetary imaging, you are using such a high magnification you will not se it clear, like in an eyepiece. More like wavy, lots of water in the air. That is why you rely on what is called ' Lucky Imaging '  a fast frame rate, video, I shot mine at 14 frames a second, and you can go as high as 50  to 80 frames a second.   After capturing in, I used Sharpcap, I stack and processed in Registax 6.  I shot 500 frames last night.
If you do not have a planetary camera or dedicated astro camera, what I would try to do is focus the best you can, I made a Bahtinov mask, printed a paper from the internet and cut the pattern on EVA foam I got from Hobby Lobby. I glued the foam to a thick piece of cardboard.  Links below.  I focused on the Moons of Jupiter with the mask.  You can also use a bright star.  After focus, shoot a video or a series of fast exposures   You can also try without the Barlow and crop / zoom in digitally.
My image after being stacked was still blurry only after I used the slides on the wavelets in Registax6 did it clear up.
I'll post my picture later, it is on another computer.
Joe
http://www.deepskywa...tinov-mask.html
Just scroll down for the size you need.
https://www.hobbylob...-5mm/p/80982129
5MM is good for masks and dew cap extensions.   If only for a mask and do not need a roll it may be available in sheets.
#5 Sacred Heart
Sacred Heart
Posted 27 September 2022 - 10:04 AM
Charlie, here is two images, the blurry one is just stacked in Registax6,  the other one is processed in wavelets in Registax6.    Both were done in same region of interest, resolution.
CFF 92 F6,  2X Powermate, QHY 462C camera.    Joe
#6 Sacred Heart
Sacred Heart
Posted 27 September 2022 - 10:07 AM
Charlie, I apologize, here is the JPEG.  Joe
#7 kevinrodgers22
kevinrodgers22
Posted 18 October 2022 - 03:39 PM
6" Alt Az Mount
FL 1500mm F/10
Electronic Focuser
Thanks;
Charlie Slate
Greenville, SC
I'm new to imaging and am just now getting around to planetary so Im not the best source of useful info but what time are you attempting your Jupiter shots? Its really low in the horizon, and I'm getting the blob effect myself. I would practice on Saturn to see what works and what doesn't for now, it isn't as temperamental to atmosphere conditions. I would try to pick up a dedicated astro cam, even an asi 120 can produce great results using lucky imaging. I'm in the spartanburg area if you ever want to try out my zwo 294
