Sky Watcher Wedge Loose Alt Screw
No replies to this topic
#1 hatflyer
hatflyer
Posted 29 September 2022 - 01:32 PM
Depending on the load orientation, sometimes in 1 direction the altitude screw has some looseness. I'm not sure how the side lever works, as I don't pull the lever away in order to rotate the altitude screw.
I tried pulling out that crank level and kept rotating it trying to find an end point, but none. Does that side lever need to be in an end-point lock-down, or does any place do as long as it is in a groove? The camera does feel very solid and no visual sign it is not.
Thanks.
