Multiple scopes with Sky Safari pro 6
5 replies to this topic
#1 lightcatcher
lightcatcher
Posted 29 September 2022 - 08:45 PM
Can you have two different scopes set up in Sky Safari 6 Pro without losing your current telescope configuration? I have it currently setup with my Sky-Watcher 8" Dob as a "PUSH TO" and Nexus II.  I was curious if you could attempt to add another scope in Sky Safari without losing all of the set up Data/ configuration.  Is this just something that I will have to configure every time a switch is made?
I though about this because I went out with a friend and he has a Sky-Watcher 12" dob flextube "GOTO" with SynScan and accompanying app.  I Brought my laptop with Sky Safari and we used it as our sky chart but it would have been awesome to use it with the GOTO SynScan.  I just did not want to lose my original setup.
#2 wrvond
wrvond
  • Loc: Leon, West Virginia
Posted 29 September 2022 - 08:57 PM
In all the versions of SkySafari I've ever had (several) I've always had all my GoTo telescopes configured and could select and control any one at any time. What you can't do is control more than one at the same time.
#3 lightcatcher
lightcatcher
Posted 29 September 2022 - 09:16 PM
I added a scope under "telescope" then "equipment tab, however the "setup" tab was still configured for the original scope.  I do not see any options to switch or choose between scopes.
Do all your scopes use the same GOTO program, such as SYNSCAN?
Do you have to choose the Equipment manually when you fire up sky Safari and connect your scope?
#4 wrvond
wrvond
Posted 29 September 2022 - 09:43 PM
Setup is where you select the interface between your telescope and tablet/phone. When you select “telescope” on the menu bar and it opens “connect and align” etc. that is using the connection device listed in setup.
Selecting “scope type” will allow you to choose the wifi device.
When you select “observe” that is where you choose your telescope and eyepiece, this only affects the view presented within SS.
Edited by wrvond, 29 September 2022 - 09:45 PM.
#5 Raginar
Raginar
  • Loc: Louisiana
Posted 30 September 2022 - 09:01 AM
Yea, you build profiles for them.
#6 scuba14c
scuba14c
Posted 11 November 2022 - 07:32 PM
Sorry to hijack the thread, but I am having problems setting up 2 mount types within skysafari 6 on Android. My screen looks like the attached picture and it doesn't appear I can have 2 mount types configured. Can anyone help with this?
