5v Svbony Dew straps on asiair plus
6 replies to this topic
#1 golfermike22
golfermike22
Posted 02 October 2022 - 11:41 AM
Newbie getting into this wonderful hobby.  I have astro-tech 70ed.  I have been able to use my asiair plus learning and watching every day.  I definitely need a dew strap as experienced the couple of nights photographing.
My question is if I buy the svbony dew straps which claim to require 5v, can I use the 12v power ports on the asiair and control the power output?
#2 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 02 October 2022 - 12:33 PM
The 5v ones are USB powered. Probably just better to plug into a USB port.
#3 golfermike22
golfermike22
Posted 02 October 2022 - 03:24 PM
I'm trying to avoid using the usb port.  Thanks for the reply.
#4 Cliff Hipsher
Cliff Hipsher
  • Loc: North Chesterfield, VA
Posted 03 October 2022 - 09:48 AM
Measure the circumference of the dew shield on your 70ED.  Go to Agena Astroproducts
Find a heater with the same length as the circumference of the dew shield.
Go to eBay and get some of these connectors : https://www.ebay.com/itm/125210296382
Now you can cut the heater cord to the length you need, solder on the new connector and you're ready to rock and roll.
Edited by Cliff Hipsher, 03 October 2022 - 09:51 AM.
#5 hlee
hlee
  • Loc: Toronto, Ontario, Canada
Posted 03 October 2022 - 02:47 PM
You'll have to check the voltage required/supplied, but you should be able to use a cell phone power bank.
https://www.amazon.c...ef=nb_sb_noss_1
Make sure it's not a charger but a power bank something that actually contains a battery.
Edited by hlee, 03 October 2022 - 02:51 PM.
#6 Enance42
Enance42
  • Loc: Alton Il.
Posted 04 October 2022 - 07:14 AM
I have 3 of the USB dew straps and run them off of a power pack like the previous post suggests, works great.
#7 MellonLake
MellonLake
  • Loc: Toronto, Canada
Posted 04 October 2022 - 01:32 PM
You need to know if the 12V output is pulse width modulated or voltage modulated.  If it is voltage modulated you can figure out what setting represents 5V and limit the voltage to less than 5V. If it is PWM modulated I would not try it.
In general, I would not recommend trying to run 12V through a 5V resistive heating device like a heater band.  This would likely cause the band to either failure immediately or degrade quickly.  I did a quick calculation assuming the power output at 5V is 2W  at 12V the power output would be almost 12W or nearly 6 times that at 5V.
Rob
