Can the ASIAIR Plus power the EQ6R Pro Mount?
8 replies to this topic
#1 Young Padawan
Young Padawan
  • Loc: New Jersey, USA
Posted 03 October 2022 - 08:48 PM
Greetings,
Does anyone know if I can use one of the four 12V DC Outputs on the ASIAIR Plus to power my EQ6-RI mount?
If so, what cable do I need? (please send link).
The only cable that I currently have for powering my mount, is the cigarette lighter type, which obviously won't plug into the ASIAIR Plus.
Clear Skies!
#2 Enance42
Enance42
  • Loc: Alton Il.
Posted 03 October 2022 - 09:03 PM
The EQ6R is better off with its own power source. The ASIair Plus has 6 amps available total (maybe only 5) between the 4 outputs. The mount will draw up to 4 amps by itself.
#3 hyiger
hyiger
  • Loc: East Bay, CA
Posted 03 October 2022 - 09:14 PM
I power my EQ6-R Pro with the ASIAir Plus. I use this going into the mount: https://starizona.co...1e2e7d3dd&_ss=r and this going into the air: https://starizona.co...-adapter-12v-dc
Max I've seen it draw is just over 2 amps when slewing at the maximum motor speed with 30 lbs of equipment. I also power 2 cameras (1 cooled) and the focus motor.  Maybe I'm playing with fire (literally), but so far after 4 months no issues.
Edited by hyiger, 03 October 2022 - 09:25 PM.
  • Jay6879 and Loopster like this
#4 bearpig
bearpig
  • Loc: Peach Mountain Observatory, 42.3N
Posted 03 October 2022 - 09:28 PM
Can? Yes.
Better off not. I am going to say this is opinion rather than fact. I personally have not had control board trouble.
  • mariemarie likes this
#5 charles.tremblay.darveau
Posted 03 October 2022 - 11:04 PM
2 amps is for max slew in one direction. If you do a slew in both DEC/RA then both motors run which can pull up to 4amps. Just had to test this for a pegasus power box. That's a lots of amps.
I would avoid running the EQ6-r from the ASIair pro. It's just too power hungry.
#6 Drothgeb
Drothgeb
Posted 04 October 2022 - 04:26 AM
I’ve done it when using the scope for visual. But I wouldn’t do it with camera cooling and dew heaters on.
For the cable I bought the coaxial and aviation connectors and made my own.
#7 astrohound24
astrohound24
  • Loc: Western Kentucky
Posted 04 October 2022 - 04:30 PM
I got mine to run off it, but the LED power light on the mount kept flashing and I understood that to be a warning that it was suffering from low power.
GM
#8 unimatrix0
unimatrix0
Posted 04 October 2022 - 07:58 PM
BTW, you can make your own power cable much cheaper.  I'm just saying, because I consider it , once I'll get power cable problems
https://www.amazon.c...B08YF1FQ1X&th=1
and
https://www.amazon.c...nics,92&sr=1-11
#9 Drothgeb
Drothgeb
Posted 05 October 2022 - 05:29 AM
and
The ASIair comes with so many power cables, it works well to add a aviation connector to one of those. Hardly ever gets used, but it looks good.
