10" f/10 Thompson Optical Refractor
215 replies to this topic
#51 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 27 February 2023 - 07:04 PM
Maybe the previous owner was going for a poor-man's Great Melbourne Telescope? lol.gif lol.gif
Gonna need a long ladder if it is a 40" F/8 Newt. I would be way too scared to go that high. Plus it's not gonna fit thru my door.
#52 Kasmos
Kasmos
  • Loc: So Cal
Posted 27 February 2023 - 07:05 PM
In the drawing it looks like it has a secondary, so I guess it's a long Cassegrain. Interesting that it's outside with no visible way to protect it.
  • jragsdale likes this
#53 jragsdale
jragsdale
  • Loc: Idaho
Posted 27 February 2023 - 07:12 PM
#54 Kasmos
Kasmos
  • Loc: So Cal
Posted 27 February 2023 - 07:13 PM
#55 clamchip
clamchip
  • Loc: Seattle
Posted 27 February 2023 - 08:33 PM
They probably did it like Mr. George Hole:
https://www.britishp...arden-telescope
Robert
Edited by clamchip, 27 February 2023 - 08:33 PM.
  • Vesper818, ianatcn and mikerepp like this
#56 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 27 February 2023 - 10:14 PM
I would surmise if the OTA was used in daytime for filming parachute tests,  the holes were vents so heated air in tube from it being in Sunlight could escape so as to not degrade the images.
Dave
#57 jragsdale
jragsdale
  • Loc: Idaho
Posted 27 February 2023 - 10:57 PM
Dave
No, the previous owner did it with a crude hole saw to try to shave weight off the front because he had a hard time balancing it properly with a 3 foot tall Cave Astrola mount meant for a reflector. Did I also mention he also put a 60lb bucket full of concrete in the back end of the scope?
  • mikerepp likes this
#58 jragsdale
jragsdale
  • Loc: Idaho
Posted 01 May 2023 - 09:02 PM
Well, the universe once again finds a way, after casting a wide net, the absolute PERFECT mount of my dreams has fallen into my lap. An UNUSED Schaefer AT-12 with an extra long saddle and a 5 foot x 10" portable pier. And it's relatively nearby so I can pick it up. This mount should be able to carry 2 of my 10" refractors it's so beefy. And I'm an absolute Schaefer fanboy, so this is a dream come true for me!
And 2 short months later, the mount is in my hands, tuned up and setup to hold this scope. It's an absolute dream, so smooth and stable!
  • Paul Hyndman, davidmcgo, m0bius and 16 others like this
#59 djgilley
djgilley
  • Loc: Orange City, Florida
Posted 01 May 2023 - 09:26 PM
I wondered how things were going with the 10 inch refractor, Jordan...what a mount! Have you scared up a Chromacor for it yet? Or do you use it mainly for deep sky?
David
#60 jragsdale
jragsdale
  • Loc: Idaho
Posted 01 May 2023 - 10:55 PM
David
Chromacor is definitely on the want list for this beast. I still have a LONG way to go before the scope is where I want it to be. The CA is not as offensive as you'd think, so I've had good views of the solar system objects, the moon is fantastic with a Semi-APO filter at high magnification. And the 13% ND filter generally used as a moon filter works well on Venus visually. But it does excellent on DSO objects as expected.
  • steve t and djgilley like this
#61 jragsdale
jragsdale
  • Loc: Idaho
Posted 01 May 2023 - 11:46 PM
Captured Venus tonight with the 10".
ASI290MM + 2x Barlow + Green CCD Filter
50k frames, best 2k stacked
Drive corrector was great to have to keep the planet center in the ROI.
  • jgraham, drprovi57, photiost and 21 others like this
#62 CHASLX200
CHASLX200
Posted 02 May 2023 - 06:12 PM
How smooth is hand centering objects? Don't look that big with that scope or my eyes are playing tricks.
#63 jragsdale
jragsdale
  • Loc: Idaho
Posted 02 May 2023 - 07:09 PM
DEC is like butter, but the RA is a little tight still. It's a brass friction clutch that's unlubricated and helps hold it tight when you engage the polar thrust washer. So it goes in this order from south to north: thrust knob, Teflon washer, polar shaft, polar casting (rear brass sleeve, front ball bearing), front of polar casting, large Teflon disc, RA gear (w/setting circles mounted on side), brass friction clutch, front face of polar shaft, DEC casting. Trying to add some extra slip without slipping while tracking.
I should take the picture with me in it for scale. It's giant, lens is almost 10 feet off the ground when at the home position.
Edited by jragsdale, 02 May 2023 - 07:10 PM.
#64 CHASLX200
CHASLX200
Posted 02 May 2023 - 07:16 PM
My 2.5" Cave mount was heavy as sin.
  • deSitter, Serenity Now, JonH and 6 others like this
#65 jragsdale
jragsdale
  • Loc: Idaho
Posted 02 May 2023 - 07:32 PM
Do you know what it weighs sans counterweights? I'm at 215lbs on this Schaefer. But it's way more of an efficient design with its large thrust face and RA gear. Much more stable than the Cave T style EQ mounts.
Edited by jragsdale, 02 May 2023 - 07:40 PM.
#66 jragsdale
jragsdale
  • Loc: Idaho
Posted 02 May 2023 - 09:33 PM
Ok, here's me for scale and I'm 6'0".
  • davidmcgo, deSitter, photiost and 19 others like this
#67 Sean Cunneen
Sean Cunneen
    Let Me Think
  • Loc: Flossmoor Il.
Posted 03 May 2023 - 05:26 PM
The mount is about 2ft too short. You'll have to sell it to me.
  • jragsdale and firemachine69 like this
#68 jragsdale
jragsdale
  • Loc: Idaho
Posted 03 May 2023 - 05:59 PM
I plan on adding a finder scope and some other things on the back end (counterweights) so I can slide the tube up the rings quite a bit. Plus a taller more heavier duty rolling base for it to lift it another 6" or so. That should get it into comfortable viewing height for all parts of the sky. Nice try though. ;)
  • Dave Trott likes this
#69 CHASLX200
CHASLX200
Posted 03 May 2023 - 06:07 PM
All the Cave, Meade , Parks and Starliner mounts were never made right.  Something like your mount or my AP800 was a much better mount as all them other mounts had a small thrust area.  My mount with the pier i had made was around 300lbs with the one weight you see in the pic. Maybe your mount is made with steel?  I never seen one ever in real life as i don't think one has ever been in my part of FL. I guess i will never luck into a mount like that. But if you get tired of it and wanna come enjoy the beach  i will make a good offer..  I think i could roll it out pretty easy on a short pier.
  • deSitter likes this
#70 CHASLX200
CHASLX200
Posted 03 May 2023 - 06:09 PM
Looks like i could use it at my house for the 826.  Not sure the 826 is heavy enough to work even without weights.
#71 deSitter
deSitter
    Still in Old School
Posted 03 May 2023 - 06:16 PM
Man that's amazing! Those rings seem awfully thin. Why skimp on material there? It's just a thin mint to that mount :)
-drl
#72 CHASLX200
CHASLX200
Posted 03 May 2023 - 06:19 PM
Man that's amazing! Those rings seem awfully thin. Why skimp on material there? It's just a thin mint to that mount smile.gif
-drl
Them rings are strong. I have had many made my man for many scopes.  They are solid.
  • deSitter, Bomber Bob, LU1AR and 1 other like this
#73 jragsdale
jragsdale
  • Loc: Idaho
Posted 03 May 2023 - 11:18 PM
-drl
They're 1" thick Parallax rings. Very sturdy and heavy duty. Definitely not worried about those. I think they look small because it's so big. lol.gif
  • CharLakeAstro likes this
#74 jragsdale
jragsdale
  • Loc: Idaho
Posted 03 May 2023 - 11:49 PM
Starting in on the 2nd OTA now; got the backplate and baffles removed, now to get 10" cut off the tube and the baffles so it can reach focus.
  • Terra Nova, mikerepp, Kasmos and 6 others like this
#75 Sean Cunneen
Sean Cunneen
    Let Me Think
Posted 04 May 2023 - 03:33 PM
I am a big fan of hose-clamps and a hacksaw. Only way to get a nice straight square cut. It takes a while, but its worth it!
