Had a buddy laser cut a thin wooden mask for the new 10" lens. It's actually a 10.25" clear aperture and there's a few small edge chips I wanted to hide so he made me a press fit thin wooden ring so I can step it down to 10" even. It's the little things! Got it painted flat black and installed. Ready to go!
10" f/10 Thompson Optical Refractor
#77
Posted 16 May 2023 - 09:14 PM
I am a big fan of hose-clamps and a hacksaw. Only way to get a nice straight square cut. It takes a while, but its worth it!
Where do I get 13" OD hose clamps?
Today I cleaned up the nameplate on the scope and removed all the old white lacquer in the engraved reliefs and replaced it with black lacquer stick. Turned out pretty good! That lacquer stick is pretty slow to dry so I'll give this a good 2 weeks then give it a very light wet sand with 800 grit to brighten up the metal and increase contrast then top coat with a thin car wax for protection.
- deSitter, Serenity Now, Terra Nova and 7 others like this
#78
Posted 19 May 2023 - 02:07 PM
You can chain them together, 2 8" clamps should do the trick.
#79
Posted 19 May 2023 - 02:38 PM
I didn't even think of that! Good idea!
#81
Posted 28 May 2023 - 03:16 AM
Just found a Chromacor for $550 to add to this scope! Woohoo!
That's a steal!
-drl
- mdowns and Terra Nova like this
#82
Posted 01 August 2023 - 01:56 PM
How are things coming along with the new tube and all your mods?
Rob
#83
Posted 01 August 2023 - 10:04 PM
Rob
I've been at a standstill on the rear flange, I took it to a machine shop and they wanted $1200 for all the mods I needed. But I found a local friend with a big 12" lathe who was able to do them well, and much cheaper, but he's busy too so he's still working on it. But basically having a large 6½" new rear adapter made that has an M90 male threads to accept a nice 2.5" TS focuser. Once I get that in I'll cut the tube a little shorter (~10") then should be able to reinstall everything and get it going. After everything fits well and is as functional as I want it, I'll start on the cosmetics to really make it pop.
#84
Posted 01 August 2023 - 11:59 PM
I would be tempted to build a Berry mount for it.
But what you have there might be good enough to see what you have in the optics.
I'm in the middle of a similar project with a unknown 8 inch f/6 mirror, I'm temporarily using another
tube to see what I have. If I like it I'll give it a structure and mount to match its performance.
Robert
Here is a simple Berry that works with a 16 kg 7 inch f-8 ota and an 11 kg 6 inch f-12 ota.
- Terra Nova, jragsdale, brlasy1 and 2 others like this
#85
Posted 02 August 2023 - 12:18 AM
I'd be interested to see what kind of Berry mount this OTA would take. It'll be about 55kg when it's all done.
- LU1AR likes this
#86
Posted 02 August 2023 - 12:07 PM
It is possible but obviously you would need to scale up.
I have used 8 inch bearings for these relatively light scopes. The tripod is made from 4" x 2" pine and has strong door hinges connecting the legs to the mount. The weight of the ota and counterweight locks it in place.
You might want to use metal for some parts. I used 25 mm marine ply for the Berry mount. My ota's are made from PVC and plywood. The red one is a hexagon.
Both can handle 250 X and work smoothly.
If your scope used precision made 12 inch or larger bearings it should work well. Although I think it would be best in a permanent set up. Still with careful thought and a couple of strong astronomers it might be possible to make it semi portable.
Edited by Kevin Barker, 02 August 2023 - 12:13 PM.
- LU1AR and Weisswurst Josef like this
#87
Posted 02 August 2023 - 12:43 PM
My cousin has a 24" lathe....so I was able to turn and machine my aft plate....focuser mount on it. I found a 1/4" thick 12" aluminum pressure pot that I used for the back plate for my 10"f/15. Just a bit of machining and bammm! She slipped right onto the 12"tube perfectly. Here are some pics of the lathe job and the fitting of the painted aft cap with the 6" focuser interface.
Rob
- deSitter, Jim Curry, clamchip and 13 others like this
#88
Posted 02 August 2023 - 01:46 PM
Rob
wow nice
-drl
#89
Posted 02 August 2023 - 04:36 PM
That's pretty similar to what I've got, my back plate is 12¾" OD and about 2½ thick. Here's what I'm starting with. And I ordered a big chunk of aluminum to turn down to fit this that steps down to M90 eventually. I'll post more pics when it gets close!
- deSitter, JonH, Terra Nova and 5 others like this
#90
Posted 03 August 2023 - 01:03 AM
...pretty late reply on the question of larger hose clamps: you can actually buy lengths of the clamp strip (I got a 3 metre length) and buy the worm fittings separately...air-conditioning/ducting suppliers are the places to get these.
- ANM and shredder1656 like this
#91
Posted 03 August 2023 - 07:48 AM
2.5" thick? Wow..that is a hunk of metal. You must be using it for counterweight. I chose not to do that and I mounted the counterweights externally as seen in my picture. Plus I found the pot laying around the horse paddock....and it worked for my purposes. Feed bucket to aft cap for my telescope.
I built 2 focusers for my 10". One has a standard 2" draw tube. that is internally driven electrically and the other is a *Huge* 6" focuser with an internal adjustable stop...made adjustable by the left focus knob, and focus by the right focus knob.
Keep moving forward...I am enjoying your progress.
Rob
#92
Posted 12 April 2024 - 12:21 PM
I've been stalled on this project for a bit working on the back-end, getting a nice tailpiece machined and deciding on the right focuser. Also today I finally cut 12" off the tube as planned, here's a video showing the process using a rotating jig with casters and an angle grinder attached to a hinged pivot: https://youtu.be/BGm...iy9RY0G38aoum6H
Things are coming together quickly now!
- ANM, Bomber Bob and djgilley like this
#93
Posted 12 April 2024 - 12:53 PM
Here's the new tailpiece that's a 6.5" insert with 4.5" x 24 this internal threads. Then I'm having a part made by a friend for 4.5" to M117 male, and these handy cheap M117 extension tubes made for large RC scopes will be the final piece before the M117 3" TS-Optics focuser with 110mm drawtube travel. The extension tubes are 2x50mm and 1x25mm so I can add or subtract as needed for things like imaging vs binoviewers + diagonal.
- Kevin Barker, JonH, ANM and 6 others like this
#94
Posted 19 April 2024 - 11:18 PM
In an effort to help add some ballast weight to the back end of the scope so it rides a little higher in the saddle, I had these shapes 3D printed by a friend that fit snug behind the baffles inside the tube. Having 4 made, fill with lead shot then top off with epoxy resin. Final weight is about 13bs after all 4 are done. That should help quite a bit!
- Terra Nova, ANM, Bomber Bob and 3 others like this
#95
Posted 19 April 2024 - 11:25 PM
Also found this used marine steering wheel on eBay for $30, I think I can cut the spokes a little shorter and spot weld them onto the baseplate. Should work pretty well as long as I can weld them together without issue.
- Terra Nova, ANM, Bomber Bob and 6 others like this
#96
Posted 20 April 2024 - 05:30 AM
Big finders are your friend for back weight. Slap on a 4" F/6 fract for a super finder with a 21mm Ethos. I hate top heavy scopes that are hung low in the saddle where ya gotta view on your belly.
Edited by CHASLX200, 20 April 2024 - 05:31 AM.
- Serenity Now, ANM, Bomber Bob and 4 others like this
#97
Posted 20 April 2024 - 07:43 AM
Yeah, I plan to put a finder or 2 on the back and a single external sliding counterweight as well. I really don't like low hanging scopes either. Big issue is I can't just mount anything through the tube as the baffles are all welded on a long rail that slides in and out of the back of the tube and they are a TIGHT fit, so if I have any nuts or protrusions on the inside of the tube then I'll have to cut out small clearance notches on all the baffles to allow it to still slide in. Or I get more tube rings, but it's a custom size and Parallax ones are spendy. Maybe I can 3D print something though?...
- norvegicus likes this
#98
Posted 20 April 2024 - 07:45 AM
Unitron like Uniclamps could help.
#99
Posted 20 April 2024 - 08:11 AM
Yeah, I think I'll 3D print something of a similar shape. I'm actually putting an Orion 80ST on the back of mine as well. It's not a heavy scope, but it'll help. And I've got a counterweight kit from an old orange C8 I can use as well. That should be enough ballast to give it a comfortable viewing height.
#100
Posted 20 April 2024 - 08:35 AM
Or go super high pier like i did on a SW150ED and AP800. I know a 10" is in another class vs a 6" and you got the added weight.
- Bomber Bob, LU1AR and firemachine69 like this
