Actually sample 3 of the objective if you count my Celestron 100ED sample.
This sample was lent to me by a local friend. He's the first and only owner of it, purchased from Orion in ~2007 or 2008 and was his workhorse scope for 10 years.
The OTA and glass looked brand new really. Speaking of the glass, I did see one immediate difference between this scope's objective and my other two samples. The lens element spacer system is a ring, instead of the three plastic tabs of my two samples.
The focuser action was smooth however, the laser fired down the tube towards a mask over the objective was off center by ~1/4 ", or roughly .4 degrees. I consider that a lot and used the attachment screws on the focuser casting to align it to within 1/16th inch. Examination of the reflection dots off of the element's rear surfaces are now aligned on top of each other forming a single dot via my Cheshire "eyepiece".
So here are the DPAC results for this sample.
First, my usual inside and outside of focus color montages made with a white LED and then separating out the blue, green, yellow, and red lights with software filtering of the white light "master image".
As you can see, except for that slight turned edge, this sample is an excellent performer with an essentially neutral spherical correction in green with well controlled spherochromatism (the ronchi lines curving in opposite directions in the blue and red). The focus points for the individual colors are really close to each other. In the white light master image, you see only slight red & green fringing around the outer lines, further proof of the excellent color correction.
The at focus image in green had its contrast hyped a bit to bring out detail and shows a mild center zone (which you can catch out with the above images as subtle disturbances in the ronchi lines) and a smooth polish.
A very nice lens which the owner, Joe, says is really close to his 100mm Tak doublet in image quality with the Tak pulling slightly ahead at higher powers (over 150x), seeing permitting.
Jeff
Edited by Jeff B, 17 October 2022 - 12:01 PM.
