Planets with a Reflector
Planet SCT Reflector Visual
148 replies to this topic
#126 rhetfield
rhetfield
  • Loc: Suburban Chicago, IL, USA
Posted 25 January 2023 - 05:08 PM
Can anyone explain the relationship between apparent field of view and true field of view and the importance of either and which matters most?
Apparent field of view is how wide an eyepiece can see.  The ones that came with my scope were 50 degree.  My current ones are 60 degree, so they see more.  True field of view is what they really see.  My 25mm 60 degree EP sees 2.3 degrees true field at 26x.  My old 25mm, 50 degree EP saw 1.9 degrees true field at 26x.  My 5mm 60 degree EP sees 0.5 degrees at 130x.  If either of these were put into your larger scope, the magnifications would be greater and true field of view smaller.
#127 vtornado
vtornado
  • Loc: NE Illinois
Posted 25 January 2023 - 05:23 PM
Looking for anyone’s opinion, input, or preference for viewing planets with a 60 degree AFOV vs a wider 82 degree AFOV?
You may get a bit more drift time with the 82.  82/60 = 40%  However off axis abberations
increase as one moves off axis, so the view in the last 11 degrees of eyepiece may not be as clean as the center 60.
Check eye relief, some widefield sacrifice eye relief.
I had an ES82, and it was just as sharp on planets and moon than an dual ed.
Astigmatim is not that important with small exit pupils.  I have mild astigmatism
and it does not negatively impact the view until 4 or 5mm exit pupil.
For planets I do not wear my glasses.
  • Ionthesky likes this
#128 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 25 January 2023 - 06:18 PM
Thanks, I appreciate everyone’s continuing feedback and find it informative and very helpful. In all due respect to JohnBear’s comment … “anyone’s opinion, input, or preference" really doesn't count!”, it does to me and most other beginners as well. After all, I thought that was the whole point of this beginners forum section. Are we not supposed not supposed to read the books that have been suggested either? we may ask silly questions sometimes, but that’s because we’re starting off with no experience. Varying points of view are not meant to be copied, but rather used to assist in making an informed decision. Back to the task at hand, when saying that wider views may offer some blurred viewing on the outer edges, but is sharp in the center, do you find it a worthwhile trade off for the longer period that the object remains in view?
  • Dave Mitsky likes this
#129 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 25 January 2023 - 06:22 PM
At this point, due to wearing eyeglasses and having a fair astigmatism, the eye relief will be one of my top concerns with making a choice. Especially since I understand that the stated specifications for eye relief aren’t necessarily correct in reality.
#130 Dave Mitsky
Dave Mitsky
Posted 25 January 2023 - 08:19 PM
Your telescope has a focal ratio of f/5.9.  I wouldn't worry about eyepiece astigmatism, if you buy an 82-degree eyepiece that is corrected for it.  I would avoid 70-degree 5-lens element Erfle and Erfle variant designs, however.
Mirror coma won't be much of an issue either.
#131 Dave Mitsky
Dave Mitsky
Posted 25 January 2023 - 08:22 PM
Part of the problem, other than outright "exaggeration", is that not every manufacturer measures eye relief in the same manner.
  • CowTipton and Ionthesky like this
#132 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 25 January 2023 - 09:00 PM
Dave, if it wasn’t that my eyes have a moderate astigmatism, I would not even wear glasses when viewing as otherwise I am only farsighted. That is my only concern with the eye relief. I do have a few basic eyepieces, but I really would like and intend to upgrade to something better without breaking the bank. I am comparing the Celestron X-cel LX, AT Paradigm Dual ED ( or Agena Starguider Dual ED), and the AT UWAs. I also currently have an Orion high power 2x 4 element Barlow. In a nutshell, this is what I am trying to decide on. Other than getting a optical finder scope ( likely a RACI), to replace the red dot which is impossible to use with it’s location on my scope and no available space to move it to because of the phone cradle on the top of the tube for the StarSense, I am all set to go! As far as choosing sizes, if I understand correctly, after factoring the focal length of the scope, I choose pieces based on the magnification that I want and the AFOV that I prefer. The only other thing that I don’t quite understand is what the difference is between a fast or slow scope? Not which ratios are which but rather what is the difference with the viewing? Wow, that was a mouthful, but it summarizes the only concerns or questions that I have at this point. Sorry for being so windy and hope the long post isn’t bad etiquette.
#133 Dave Mitsky
Dave Mitsky
Posted 26 January 2023 - 01:01 AM
I was addressing the astigmatism that is present in wide-field eyepiece designs that don't have additional lens elements to correct for it, not any astigmatism present in your vision.  Eyepieces like Erfles work fine in slow telescopes but not so great in fast ones.
https://skyandtelesc...scope-eyepiece/
Disregarding issues like coma, central obstruction, and chromatic aberration in refractors, images at the same magnification should appear about the same in fast and slow telescopes of the same aperture and optical quality.
While an eyepiece's focal length determines the optical system's magnification, the f/number is of little importance visually. A "fast" telescope implies a short focal length and a large field. Fast, however, is a term borrowed from photography (an f/5 telescope can take a photograph with one-fourth the exposure time of an f/10 instrument).
Visually, well-made fast and slow telescopes of the same aperture have no difference in image brightness or resolution. I find that photographers have the most difficulty understanding this concept, because their experience that a faster f/number means brighter images on film and in the viewfinder is so ingrained.
https://skyandtelesc...-magnification/
Myth #3: Faster telescopes show brighter images.
This is a misconception carried over from photographic use, where the fast f/ratios do mean brighter images and shorter exposures for extended objects. Telescopes with equal apertures and equal magnifications have the same visual image brightness, regardless of the objective's f/number.
Myth #4: Long-focal-ratio telescopes give higher-contrast images.
In general, refractors offer the potential for higher contrast because mirror coatings, by their nature, tend to scatter more light. But when comparing well-made, highly corrected refractors, there is no gain in contrast with instruments of long focal ratio.
Reflectors too, if well made and having the same size of secondary obstruction, will have the same contrast at the same magnification regardless of the f/ratio.
https://www.televue....rn=Advice&id=86
#134 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 09 February 2023 - 01:38 AM
If collimation is ok, when you see spikes coming from the object and can’t completely remove them from the object observed, can it just be from turbulence or bad seeing?
#135 vtornado
vtornado
  • Loc: NE Illinois
Posted 09 February 2023 - 12:48 PM
Spikes are from the spider vanes.
#136 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 09 February 2023 - 11:05 PM
What do I do to fix it? I can get it close to normal but slightly over or under focusing then I see the spikes or starbursts
#137 JohnBear
JohnBear
  • Loc: Sandy, Utah
Posted 10 February 2023 - 12:18 PM
Just do a google search on "diffraction spikes" for more detailed info. Note that even Hubble and JWST show diffractions spikes on point sources of light.
To reduce or eliminate them you will need a more expensive telescope or do some tricky reengineering on your current telescope, to eliminate the effects that spider vanes produce if you really want be viewing 'point sources of light'.
Edited by JohnBear, 10 February 2023 - 12:30 PM.
#138 CowTipton
CowTipton
  • Loc: NW Chicago Suburbs
Posted 10 February 2023 - 01:27 PM
Nothing without changing the secondary spider vanes.
It's part of the design of a reflector telescope.
Use the diffraction spikes to your advantage.  When focusing, try to get them as thin as possible.  That's usually your best focus point.
#139 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 10 February 2023 - 03:12 PM
do they primarily show on the brighter stars and less on others?
#140 gnowellsct
gnowellsct
Posted 10 February 2023 - 03:27 PM
Apparent field is what you get when you hold the eyepiece up to the sky without putting it in a telescope.  It's the chunk of sky that the eyepiece will let in.
Once the eyepiece is conjoined with a telescope the scope is gathering light and the eyepiece is magnifying it.  Your "true field" is the amount of sky you see in the scope.   It's useful because now you can estimate the size of various objects and assess which eyepiece is best suited to the size of the object.
Greg N
#141 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 11 February 2023 - 05:51 PM
When setting your dob outside to cool down for viewing, is it best to leave dust cap on the end of tube or take it off? I realize the tube must cool down inside, I only ask not knowing if leaving it off while not viewing unnecessarily allows for any dust/ particles to enter. Over the course of time, is there anything that needs to be done to remove any dust that might have accumulated inside the tube? I am not talking about removing or cleaning the mirror.
#142 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 12 February 2023 - 06:45 AM
Does leaving it off during observing allow unnecessary dust to enter? I guess the point is, it doesn't hurt much to leave it off because it's going to be off while you are observing anyway. I leave mine off with the fan blowing. But more to your question, it's the mirror that needs to cool. So long as air is blowing on it, then it will cool. It would be nice to exhaust some of that warm air out of the tube. One option is to put the dust cap on and leave the focuser open. You may be shocked how much air blows out of your focuser when the dust cover is on. Try it. Surely enough to keep any dust from floating in.
  • JohnBear likes this
#143 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 06 March 2023 - 06:21 PM
When viewing a very bright stage of Venus, does it create diffraction rings as a star would?
#144 Nightskyman
Nightskyman
  • Loc: Pennsylvania
Posted 07 March 2023 - 08:45 PM
What are some of the best 8” dobs that anyone likes?
#145 drneilmb
drneilmb
  • Loc: Decorah, IA, USA
Posted 07 March 2023 - 10:04 PM
I hear lots of good comments on here about the Aperture AD8 and the Orion XT8. There are some other brand names that will also have models very, very similar to those two.
#146 Dave Mitsky
Dave Mitsky
Posted 08 March 2023 - 01:33 AM
The 8" Orion Skyline Dob is a bit more upscale than the 8" Orion SkyQuest XT8.
https://www.telescop...pe/p/113094.uts
There are also the 8" Sky-Watcher 200P Dob, the 8" Sky-Watcher Flextube 200P Collapsible Dob, and the 8" Celestron Starsense Dob.
https://www.skywatch...er-classic-200p
https://www.skywatch...r-flextube-200p
https://www.celestro...onian-telescope
The 8" Zhumell Z8 Dob apparently is currently not available.
https://zhumell.com/...ector-telescope
#147 Palmsnbananas
Palmsnbananas
Posted 08 March 2023 - 10:12 PM
For me Jupiter is best at 10mm to 5mm, I like 7 or 9mm focal length.
At higher mags it becomes too blurry
My Focal length is 1200mm so probably same as yours
#148 SteveG
SteveG
  • Loc: Oceanside, CA
Posted 09 March 2023 - 12:39 AM
What is the CYL on your viewing eye (from your prescription)?
From this we can tell you at what magnification your astigmatism will affect the view. Typically, it’s only lower powers. High power views typically have a small enough exit pupil that no astigmatism is seen.
#149 SteveG
SteveG
Posted 09 March 2023 - 12:41 AM
IMO all current Chinese dobs are of equal optical quality. It’s just a matter of mechanical features and accessories. It’s an incredible time to buy quality telescopes & accessories as compared to when I started this hobby.
Also tagged with one or more of these keywords: Planet, SCT, Reflector, Visual
