If they really wish to pursue it further, then I recommend finding a good, solid tripod and a small, but solid manual mount. IMO, that matters more than what scope you put on it. To me, nothing kills the hobby quite like a wobbly tripod where they can't even focus without the image jumping in and out of the FOV. Then...I will now recommend a small refractor. Perhaps even binoculars to start off with.
One of the advantages of a 6 inch F/8 or 8 inch F/6 Dobsonian is that the mount is rock solid. Solid tripods are expensive. Starting off with a good tripod is a good way to get a solid start with a small refractor.
Twenty five years ago, I was at a swap meet and saw a Bogen 3040 tripod. I had $30, the seller wanted $35. The nearest ATM was a mile walk, each way. It was late, I was tired.. I decided I'd go for it. Over the years, that Bogen 3040, a 3046 tripod with an old style 3047 head has been my most used tripod/mount. It's evolved to the point that today I'm using it mostly as a portable observing table.
I often think about how different things might be if I had decided not to walk those two miles to get the money. Today, the modern versions of the 3046-47 combo is over $600.
I believe Ed Ting, in one of his videos, pointed out that paradoxically ‘beginner’s refractors’ are really much better suited to an experienced user than a neophyte. Almost all of them have wobbly mounts such that it doesn’t matter how good the optical tube is if the presented image bounces all over the place.
That's been my experience.. Last night I was doing a small refractor "shoot out."
I had two scopes setup, the 60 mm F/7 Svbony. It was not mounted on the stock tripod. Instead, it was riding on a vintage Linhof professional tripod. The eyepieces were not the stock eyepieces, rather, I was using a mix of Astro-Tech Paradigms and Type 6 Naglers.
(Winter in San Diego is not always this nice.)
The second scope was my 4 inch F/5.4 TeleVue NP-101.. it wasn't really a shoot out.. I just had the two scopes setup.
The seeing was quite poor but one of the goals for the evening was to see if I could split Izar with the Svbony 60 mm. I'd gone to bed but about 1 am, woke up and went outside to give Izar a go in the Svbony. I went as high as 164x. I thought I could see something but it was not definitive. I gave Izar a try with the 4 inch, there was something more there but it wasn't definitive either so there's still hope for the little Svbony.
Splitting Izar would be quite an accomplishment for a 60 mm F/7 achromat. It's a challenge for longer slower achromats. But as John and Mark point out, this was an inexpensive beginners telescope but I'm not a beginner and the scope was surrounded by quality accessories. Each "basic" Paradigm eyepiece cost as much as the telescope.
