It takes scopes of all sizes. Outreach needs 80 mm refractors and 10 inch Dobs. Before COVID, I'd setup an 80 mm plus a Dob.
Both were bought used. The Dob was $240, the refractor, $425 plus the mount.
You are right.
I mean, if during outreach you have ALSO the small scopes, it is easier to convince people that they can actually have a telescope.
If you have ONLY the larger ones, it can be intimidating, even if you answer a direct question about how much it costs (people can be even intimidated by the size, the volume, the portability, the perceived complexity) .
I am also talking about the situation in Italy, where at outreach events large dobsonian telescopes were rare (nowadays are a bit more common), while either large catadioptric telescopes were more common, starting from 127mm Maksutov and 20 cm Schmidt-Cassegrain, or big newtonians mounted on equatorial mounts. I know in the USA is much more common to find dobsonians even at outreach events.
Having also smaller, child-friendly telescopes in this case can be a plus.
