I'm having an issue with NINA on my mount-side computer. It simply refuses to start. I have uninstalled, rebooted and reinstalled multiple times, with multiple versions of NINA. When I look in Windows Event Viewer, it is throwing an error that appears to be related to the display and creating a window:
Application: NINA.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32, IntPtr)
at MS.Win32.UnsafeNativeMethods+HRESULT.Check(Int32)
at System.Windows.SplashScreen.CreateLayeredWindowFromImgBuffer(IntPtr, Int64, Boolean)
at System.Windows.SplashScreen.Show(Boolean, Boolean)
at NINA.App.Main()
I get a NINA crash dump that is over 170MB, but no debug log. That makes me wonder if the issue is that I'm running the whole system over Remote Desktop, and don't even have a local monitor connected. It runs just fine on the machine that I use inside the house...
Does that sound reasonable, and if so, how do I fix it? Or is there something else I should try. I have only the windows native security software, no other real-time AV (just Malware Bytes, which run periodically).
Any suggestions?
