Pixinsight And DSS
16 replies to this topic
#1 cashd115
cashd115
  • Loc: Mount Airy, NC
Posted 24 November 2022 - 05:14 PM
Obviously, I haven't used flats for this, but the alignment still looks off even after using star alignment in pixinsight. Could this be from DSS?
Here are all of the files, there is a jpeg in the dated folder.
https://drive.google...?usp=share_link
Edit: There is also very, very, very little integration time. 7 each LRGB @ 180 seconds and 15 darks at 180s. I'll get flats later.
Edited by cashd115, 24 November 2022 - 05:36 PM.
#2 Professor2112
Professor2112
  • Loc: Massachusetts
Posted 24 November 2022 - 05:18 PM
Your image isn’t visible if you had meant to post one.
#3 cashd115
cashd115
Posted 24 November 2022 - 05:20 PM
I think I fixed it it’s in my Google drive
#4 sharkmelley
sharkmelley
  • Loc: UK
Posted 24 November 2022 - 05:55 PM
Your question is a bit confusing.  Why would DSS affect star alignment in PixInsight?  Or are you doing the star alignment in DSS?
#5 cashd115
cashd115
Posted 24 November 2022 - 06:12 PM
That’s why I’m asking I may be doing something incorrect. I’ve used PI once now. I stacked LRGB as individual channels with a master dark in DSS. I processed the 4 channels as linear in PI then a LRGB combine after. Well it was bad off then. So I then went back and done a star align on the 4 channels in PI before the LRGB Combine. The resulting image is in my drive. Parts of it still look misaligned. I’m just trying to figure out what I did wrong. I can get decent data but I’m terrible at processing.
#6 imtl
imtl
  • Loc: Down in a hole
Posted 24 November 2022 - 06:27 PM
I looked at your final image jpeg in your google drive. Where do you see a problem with star alignment? I don't
#7 cashd115
cashd115
Posted 24 November 2022 - 07:27 PM
Well more specifically, it looks like a channel misalignment. There is a dust mote circled and a red spot to the left of that. Upper right of the pic.
#8 cashd115
cashd115
Posted 24 November 2022 - 07:34 PM
I mean I understand if it was a channel misalignment then everything would be off. I just don’t know what it is and I don’t think flats data will fix that red spot. There is several of those on the photo.
#9 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 24 November 2022 - 07:46 PM
Looks like your problem is because you didn't use flat frames.
#10 imtl
imtl
Posted 24 November 2022 - 07:53 PM
Like Tapio wrote above, you need to use flats to calibrate your lights. Only then stack, align etc.
You don't have any misalignment problem. You have "not using calibration frames" problem.
  • idclimber likes this
#11 cashd115
cashd115
Posted 24 November 2022 - 07:54 PM
Like my original post states I didn’t use flats and I know flats will fix the dust motes, but how will it fix the red spots? I only had two hours last night and worked today plus my rotator was at a different angle than normal so I can’t use the flats I already have. I’ll get some flats taken in the next few days. Again I’m new to PI and want to make sure it wasn’t something I wasn’t messing up there.
Edited by cashd115, 24 November 2022 - 07:57 PM.
#12 imtl
imtl
Posted 24 November 2022 - 07:57 PM
I know flats will fix the dust motes, but how will it fix the red spots? I only had two hours last night and worked today. I’ll get some flats taken in the next few days.
The red spots are dust motes misaligned when you registered the LRGB to each other. Use flats and it will go away
  • cashd115 likes this
#13 cashd115
cashd115
Posted 24 November 2022 - 08:01 PM
Thank you! Explaining why helps me understand the whole process better. “Do this” helps to but I like to know why something is wrong it helps me down the road on other problems also.
again thanks for the help guys. I’ll get those flats.
#14 imtl
imtl
Posted 24 November 2022 - 08:05 PM
Of course. And if we are not clear enough then keep asking and we'll try better :)
#15 cashd115
cashd115
Posted 24 November 2022 - 08:22 PM
You guys are always helpful, patient mostly lol. I’m terrible at explaining anything. This is literally my 4th image ever so I still have quite a bit to learn. I actually just got my setup back after a year of it being Mia/stolen. So I kind of had the same first time out excitement last night. I’m lucky I took the time for darks.
#16 imtl
imtl
Posted 24 November 2022 - 08:42 PM
Take it easy. It's a long process. Make sure you make it a fun one.
#17 cashd115
cashd115
Posted 25 November 2022 - 09:37 AM
Will do! Thanks for the advice!
