See this article which may help. Packages like Pixinsight can run multiple virtual threads from a single core hence the throughput is increased since threads are faster to execute than hardware alone.
I use the Ryzen 3950X which has 16 cores and PI uses it at a level of 32 threads- it is fairly quick however there are now faster Ryzen CPU's. If I was building a computer for PI I would use EPYC CPU's which can have "silly" numbers of cores and loads of memory however the cost would be epic!
https://www.serverba...res-vs-threads/
Edited by pyrasanth, 25 November 2022 - 10:52 AM.
