Nina and ioptron
#1
Posted 26 November 2022 - 12:47 PM
#2
Posted 26 November 2022 - 12:53 PM
Not near my imaging setup but I use Ioptron commander with my CEM70 and NINA 2.0. Works fine so it is something more subtle in your setup. I presume at this point you have connected to the mount in Commander right? For me, that is a separate step I need to do BEFORE I try to connect from NINA.
#3
Posted 26 November 2022 - 02:45 PM
I can connect the GEM45 in NINA without any prior connections to the mount. Just starting NINA and nothing else, I can go to the Equipment tab and select the Telescope icon and then click Connect and it opens Commander.
To the OP, have you looked at the NINA logs? Look for the line below and see what it's saying.
2022-11-26T13:40:15.1036|INFO|TelescopeVM.cs|ChooseTelescope|504|Successfully connected Telescope. Id: ASCOM.iOptron2017.Telescope Name: iOptron CEM120/70/40/26, GEM45/28 Mount Driver Version: 7.00
#4
Posted 26 November 2022 - 06:09 PM
#5
Posted 28 November 2022 - 10:54 AM
I discovered that my laptop virus software was blocking Ioptron commander from downloading properly. I turned it off and got Commander working and NINA worked great for platesolving and camera control.
- pedxing, marter and DanMiller like this
#6
Posted 28 November 2022 - 11:04 AM
Glad you figured it out!
