Edited by Jsterner91, 26 November 2022 - 12:51 PM.
ASI678MC and f/4 w/ Televue 2.5x
#1
Posted 26 November 2022 - 12:49 PM
#2
Posted 26 November 2022 - 01:03 PM
We have a FAQ, which will explain in more detail these answers your own questions.
Since you have 2 micron pixels, you should be aiming at approximately f/10. Focal length is irrelevant, it's focal ratio which matters.
So the 2.5x Powermate would be just fine with the f/4 scope. The f/5 Lightbridge would also be ok with the 2.5x Powermate, although a 2x barlow would be closer to ideal under most conditions.
I'm not sure why you would be considering a 5x. That would not be helpful under any of your circumstances.
#3
Posted 26 November 2022 - 03:09 PM
2um pixels and 812mm focal length equates to 0.51 arc sec/pixel.
Less than 1 arc sec/pixel means oversampling.
Stars will tend to be bloated and it may be difficult to track properly.
Ideally, one wants between 1 to 2 arc sec/pixel.
To obtain that, you'd need an effective focal length between 206 to 412 mm.
#4
Posted 26 November 2022 - 03:17 PM
This is all incorrect for planetary imaging.
2.5X will be great with that camera and those scopes.
You want to be at a focal ratio of about 5 times the pixel size in microns. 2.5x4 = 10 = 5x2.
