Hello. I recently got a 12 inch F4 dob. I had been using a 10 inch F4.7 before this.
Since the scope is pretty fast I'm going to need to use a Paracorr in general. I have an original Paracorr type 1.
Question for eyepieces. in general I'll be using a 24 panoptic, 18.2 delite, 13 Delite, 7mm nagler type 1, nagler 3-6 zoom. I have some old instructions that have the 24pan setting listed, but not sure on the others. I also don't have the TeleVue flat top 2 inch to 1.25 inch adapter that says it has 9.5mm that it adds. Mine looks to be very close...maybe 9mm.
Once I set one, I can try to adjust to the focus to find them. but I'm also unsure on the settings. One reason i question things a bit, when I used the 35mm Panoptic and focused, when I put the 24 pan in there was no adjusting to reach focus.
Let me know if there are any good tricks for this beyond winging it.
I may need to head toward the type 2, but I rather not if possible.
