LXD 75 Parts
Meade Mount
6 replies to this topic
#1 TheDudeAbides
TheDudeAbides
Posted 30 November 2022 - 12:14 PM
Hello all,
First time caller not so long time listener. Last year I inherited a Meade LXD 75 mount with a 6" schmidt newtonian scope. I have had a lot of fun discovering the night sky with it and started to take a few photos (unsuccessfully) with it. This forum has been a great resource for improving my knowledge of German Equatorial Mounts and how they track objects in the sky, so thank you to all 15 years worth of posters.
A few months back, I was slewing to a target and the counter weight bar caught on the tripod. I wasn't able to turn off the mount for a couple of seconds and now when slewing on the R.A. axis there is a nasty noise. Following the guides posted on this site http://www.weasner.com/lxd/index.html I have been able to remove the R.A. motor housing and discovered that the horrible sound is coming from the R.A. motor. At first I thought it was the encoder wheel rubbing against the LED sensor and tried to center it between the LED and sensor.  I thought maybe I damaged the encoder wheel with my meaty paws but when I put the mount back together it was slewing properly at all speeds.  So, now I am taking apart the motor to see where the sound is coming from.
In the advent that something in the motor needs to be replaced or maybe even the slightly damaged encoder wheel, does anyone know where I can find parts for this 20 year old mount?
Sleepless in Toronto,
Mark
#2 Gabby76
Gabby76
  • Loc: Slovakia
Posted 02 December 2022 - 01:42 PM
Contact Telescope Warehouse, they may be able to help you out. Normally good for all things older Meade.
https://telescope-warehouse.com
Since you are in Canada, you could take a look at the ads here. Someone may have a LXD-75 for sale and if it works well you could use it or yours as a parts mount
https://www.astrobuysell.com/in
The last possibility I can think of is the Explore Scientific EXOS-2 goto mount is (supposedly) a clone of the LXD-75. Perhaps you could get parts from ES or find a used one.
Hopefully you can get it repaired soon.
Just found this, expensive though.
https://www.teleskop...ass-mounts.html
Edited by Gabby76, 02 December 2022 - 01:55 PM.
#3 charles genovese
charles genovese
  • Loc: Madisonville Louisiana
Posted 04 December 2022 - 02:49 PM
Hey
Most likely stripped a gear.
I have various parts. PM me
Charles
Edited by charles genovese, 04 December 2022 - 02:50 PM.
#4 TheDudeAbides
TheDudeAbides
Posted 05 December 2022 - 08:25 PM
Thanks for the links Gabby. I've started down the rabbit hole of the astrobuysell shocked.gif . There is a much better market than I suspected.
Charles, I think you nailed it. I took apart the motor, took some pictures, cleaned and greased the parts before putting it back together. Here is, what I believe is the offending plastic gear.
https://www.cloudyni...-squished-gear/
I straightened the teeth of the gear using a razor blade. It looks a little more regular and when I turned the motor manually, it seemed to not catch on the mashed gear.
When I put the mount fully back together, the R.A. was running away as soon as I completed the date and time on the autostar hand set. The motor and gears sounded much better though! I was able to stop the gears by selecting align-->easy. Strangely, the display on the handset stopped displaying the alphanumerics at times. Soooo, I connected the handset to Meade's autostar suite through my computer and drove the mount that way. I was able to reset the handset and train the drive. I was then able to run the motors at all slew speeds.
Looking at the R.A. worm gear turn at slower slew speeds, it looked pretty smooth. No intermittent catching.
Of course, I created a new problem. While alternating between EAST and WEST at a slow slew speed (3 or 4) to check the backlash. There was a puff of smoke and now the mount only slews in one direction on the Right Ascension axis. Grrrrrrrrrrrrrr
#5 TheDudeAbides
TheDudeAbides
Posted 02 January 2023 - 11:01 AM
To close the loop on this thread, I'm back tracking accurately across the night sky with Charles's help. I've got a "new to me" R.A. motor assembly. I swapped out mine and calibrated the motor and voila accurate goto's.
  • Skywatchr likes this
#6 Wigleydh
Wigleydh
Posted 03 January 2023 - 10:44 AM
For future reference, the even older LDX55 has most the same parts, so parts from those could help if could be found. The LXD75 has bearings but the LXD55 has bushings on the axis.
Edited by Wigleydh, 03 January 2023 - 10:46 AM.
#7 Drothgeb
Drothgeb
  • Loc: Maryland
Posted 03 January 2023 - 10:54 PM
I have a LXD75 and an EXOS-2. They are clones kinda, but not many parts interchange. The EXOS is a belt drive.
Also tagged with one or more of these keywords: Meade, Mount
