My first scope is a Dobsonian made from a GSO OTA. The scope is attached with a single 1/4-20 machine screw which allows it to be removed easily for mounting on a GEM. Each trunnion has a screw to adjust tension. The tube can be easily balanced by loosening the rings. The trunnions are some scrap pieces of brass sitting on teflon bearings which works rather nicely being smooth and easy to adjust. The az bearing started as teflon pads running on a 12" LP record but it tended to be sticky and was replaced with a lazy susan bearing which seems to work well. So far, I have looked at the moon, Jupiter, and Saturn which yielded better views than I was expecting using 9mm Delite eyepiece. I started with a 10X50 guide scope but have changed to a Rigel Quick Finder. The one thing I don't like about this scope is the weight which is a bit much to lug around.
#2
Posted 01 December 2022 - 03:16 PM
Very nice work!
- Skyfisher likes this
#3
Posted 01 December 2022 - 03:22 PM
Very nice. What size is your scope?
You could probably lighten the base some with some cutouts, but it looks so nice I'm not sure I would.
- Ryley and Skyfisher like this
#4
#5
Posted 01 December 2022 - 03:29 PM
It is a beautiful mount
#6
Posted 01 December 2022 - 03:37 PM
Thanks! It's a 6" f6, should have mentioned it ! I think some cut outs would help and look great but tough to do now with it all assembled
#7
Posted 01 December 2022 - 03:44 PM
#8
Posted 01 December 2022 - 03:50 PM
That is unique! i love that base and the fact you can balance the OTA easily, just when I thought I’ve seen it all.
#9
Posted 01 December 2022 - 03:52 PM
That's a nice mount. Well done!
#10
Posted 01 December 2022 - 03:54 PM
I am not visualizing the mounting concept, but do hope the OP is not putting the full weight of the ota on the 1/4-20 bolt alone.
No problemo. I visualize everything which can be a problem. The OTA has rings and a vixen style rail. The rail sits on the center saddle with the single screw holding the rail to the saddle. There is also a stop along one side of the rail for alignment. Amazingly, a 1/4-20 machine screw is good for roughly a 2000# which would break the wood. The whole mount is depending on glue joints
so hope the glue is strong.
#11
Posted 01 December 2022 - 03:56 PM
Great Job!! I love the homemade touch to a telescope. You don't see that everyday
#12
Posted 01 December 2022 - 03:59 PM
This was a result of wanting to save $$$ and not knowing much about astronomy/telescopes. It was cheaper than a ready to use Dob. I worked it out in CAD before building it. I also liked the idea of being able to use the OTA on a GEM. I have three hockey pucks I need to drill for use as feet on the base (would a Canadian approve?)
- photomagica likes this
#13
Posted 01 December 2022 - 04:02 PM
Canadian here - you have official approval to drill hockey pucks What an excellent scope - nicely done!
Bill
Edited by photomagica, 01 December 2022 - 04:03 PM.
#14
Posted 01 December 2022 - 04:25 PM
LOL! all hail the hockey puck dob!
The cherry on that pie would be a couple of wood tube rings of the same wood, would be killer.
Edited by Stellar1, 01 December 2022 - 04:53 PM.
#15
Posted 01 December 2022 - 06:36 PM
I'd like a 10" f5-6 and was thinking of building one since I like woodworking. Looked into making a mirror but the blanks aren't much cheaper than a finished mirror set. When all was said and done the cost of making a scope is more than just buying one. This Dob is fun but now I know I should have gotten an 8-12". Thinking about a 10" Explore Scientific truss Dob next. My grab and go is an 80mm f7 refractor which I can grab and get to a decent site away from the city in about 45min. I remember the beautiful night sky at Algonquin Park back in 1968.
- Stellar1 and Jethro7 like this
#16
Posted 01 December 2022 - 08:52 PM
I used hockey pucks on my dob base. I glued them on with contact cement--no screws needed.
- Stellar1 and Skyfisher like this
#17
Posted 02 December 2022 - 09:27 PM
Now you need a nice wooden setting circle and angle gauge for it. Beautiful setup.
#18
Posted 03 December 2022 - 09:25 PM
Thanks, good ideas.
#19
Posted 03 December 2022 - 10:10 PM
Thanks, good ideas.
https://www.astrogoods.com/atm.shtml
This guy here makes some very nice setting circles. I have one on my scope. I attached it between the ground boards and the numbers go up in a clockwise direction. It really is like having GPS for your scope
#20
Posted 04 December 2022 - 03:26 PM
Nice but expensive for what it is. Some free ones to print https://www.cloudyni.../#entry10393721 .
I have been using the compass function of my phone for direction and given that and planisphere, maps and most importantly, Stellarium on my laptop, I have been managing so far. Stellarium is amazing for finding stuff in the night sky and I am hoping to link my refractor to it to run stepper motors for go to.
My controller kit arrived in Rochester from the Ukraine yesterday so hoping it will be delivered later in the week I may eventually do the same for the Dob since I have some spare stepper motors laying around. I'm interested in controlling simple alt/az mounts with steppers and/or mechanically.
#22
Posted 11 December 2022 - 08:49 PM
Simple method that I may copy tomorrow afternoon !
