As some of you may have gathered, I'm working to improve my planetary imaging set up. I did okay with an alt-az mount and the Celestron focuser, but I'm heading to a GEM and probably a crayford (although a used FT R/P might be in range).
What I thought I would do is set up an autofocus routine on my planetary pier akin to what I have on my deep sky pier (Mach1-->OAG-->SGP). It was for this reason that I started the thread on headless computers, thinking that was my route. I'm gathering that many of you just motor/manually set and lock focus with a Bahtinov.
I would like to hear about your processes for focusing, including hardware, software and routing, starting with the assumption of a polar and sky aligned mount. If those processes share hardware (e.g. ASI Air or NUC) with your focal process, you can certainly bring that in to the discussion as a relevant perk of your system, but ideally I'd like to walk away from this thread with a plan for focus that I can take, if not to the bank, to our good sponsors at Astronomics or elsewhere. I assume that anything I learn in this thread will be immensely helpful for EAA/outreach as well, with an eye toward my eventual retirement.
For reference, I use an Edge 8.
