Im wanting to make a dew shield using 1” insulation foam cut into staves and rounded.
I then plan to wet layup carbon fiber onto the foam and wrap it in a peel ply bleed cloth and some shrink tape https://predatorcycl...ease-tape-5-yds
Would the heat required to shrink the tape cause the foam to melt? I really dont want to go to the effort of bagging here I just want a stiff light dewshield and already have the materials leftover from other projects - except the heatshrinking polyoeflin tape. Would regular stretch wrap work if I cant use heat? I guess I could even just let it dry wet but there would probably be way too much resin stuck on the tube.
