Still on hold. I ordered some Corrosion X off amazon over New Years. They said it was delivered on the 4th. No sign of it here, so now I need to track it down or get a refund.
We love Corrosion-X! That is ALL that we use now! Of course, we order it directly from the company. We've never had a shipment lost. We wouldn't give Amazon one brass farthing! Never have! Never will! Loathe that company! Quite often we can do almost as well locally and even if we pay a bit extra, we have a live body with whom we can deal if the need arises. Also, we don't have to wait for shipping each way AND nothing gets stolen from our porch!
Two years ago we went though such a rebuild for a local school. The only difference between yours and the one we serviced is the tube counterweights. We had the optics re-coated by Spectrum Coatings in FLA. Splendid job and very quick turnaround.
It's a shame that you decided to give up on the set screw in the pedestal cap. That was actually an easy job. All you had to do was take a torch (a.k.a "gas wrench") to the area. Warming it and then dropping just about any type of penetrating fluid would have set things up for removal of the screw. Once warmed and with fluid in the hole some tension with an Allen wrench and a few taps with a dead blow hammer (We have both lead and brass hammers) would have broken it loose. Easy outs are a losing operation. In the many, many years we have seen them used, very few have not broken. They are too brittle to handle any real mount of torque which is why they are banned from the shop. They always create more work that they are worth. I'm certain someone will chime in saying that they are the bee's knees but, that's just luck, nothing more.
The most important thing when doing a restoration such as this is to have the proper tools at hand. If not, bye them. If you can't buy them then make them. We have done that on many occasions. That's why we have drawers full of extra wrenches and such. We can heat them and bend them or grind them to fit a particular job when nothing else will work. Too many projects have been mauled by not using the correct tools. Also, if you don't know how to overcome an obstacle, start asking questions. There are plenty here who can help, us included. There are very likely plenty of shops not far from your location that can offer good advice and guidance or even some of the work if it is beyond your skill level or time constraints.
FWIW
Q
