#1
Posted 03 December 2022 - 07:43 PM
#2
Posted 03 December 2022 - 08:19 PM
I use the IMX385 based sensor, which is Altair GPCAM3 385C USB3. It is a sensitive sensor and can be used for deep sky objects.
It also helps to get a focal reducer. A 0.63 and/or 0.5 focal reducer should be helpful.
Edited by Ptarmigan, 03 December 2022 - 08:20 PM.
- alan128 likes this
#3
Posted 03 December 2022 - 08:22 PM
#4
#5
Posted 03 December 2022 - 08:46 PM
I have an AP friend with the 385, and I started with the 178mm and mc versions.
For the longer focal lengths of your scope (even with a recommended reducer) the 385 would be a better solution.
If you start with a short refractor (I started with the AT72EDii) the 178 is a better (but slow) general purpose camera for EAA. I now use my 178mc as a planetary camera and intend to use the 178mm as a guide camera. My small refractor now has a role as a wide angle EAA rig with a camera that has 385 sized pixels - just more of them.
Edited by Mark Lovik, 03 December 2022 - 08:47 PM.
#7
Posted 08 December 2022 - 10:54 PM
If your budget can stretch a little, the ASI585 would be a good choice. Now at $359. Larger sensor, smaller pixels, good sensitivity, more full well depth.
j
I was going to make the same suggestion. Great price through the end of the year.
- Mark Lovik and RodgerDodger008 like this
#8
Posted 12 December 2022 - 09:07 AM
are there any images you could share?
You can search the pinned EAA Gallery topic for terms like "385MC" or "ASI385", etc., and you'll find several EAA pictures taken with an IMX385 camera.
#9
Posted 12 December 2022 - 04:14 PM
I use a 385mc if you wanted to take a look at my gallery. Be aware I'm still quite new at this so the quality of images varies.are there any images you could share?
Edited by RMS82, 12 December 2022 - 04:16 PM.
#10
Posted 21 December 2022 - 11:06 AM
For planets, small cameras can be nice because small pixels provide oversampling and small is all you need to frame the object. But In EAA, bigger format is almost always better.
- Tfer likes this
#11
Posted 22 December 2022 - 03:33 AM
I'm brand new to EAA. Trying to look at Mars tonight with my AT80ED and ASI178MC. All I got on the screen was a bright white spot like a star. Can someone clue me in to a good starting point for the exposure and gain to use for live stacking in SharpCap if it's even feasible? Also, should I be using a 2X or higher Barlow on this small target?
Edited by Mojave Red, 22 December 2022 - 03:34 AM.
#12
Posted 22 December 2022 - 08:02 AM
j
I have a ASI585MC and it really is an amazing camera for both EAA and planetary. Large sensor for the price, great wide field EAA views and with slightly smaller fov 100fps for planetary. All the images in my gallery taken with one.
- Gaitaslibre likes this
#13
Posted 07 January 2023 - 11:50 PM
I also vote for the 585. The latest generation of sensors are way better than the past ones. No amp glow, lower noise, much greater well depth, fewer hot pixels, faster frame rates.
Edited by Gaitaslibre, 07 January 2023 - 11:52 PM.
