Hi Everyone,
I've recently taken delivery of a 20" SkyWatcher and have some concerns about the steel drive cable.
I'm not mechanically minded, so would really appreciate any opinions and ideas from someone who has experience with this sort of thing.
1) The cable I have is fraying in 4 or five places along it's length. I've cut off (the 1cm long) frayed ends. The cable works fire, and I only notice the frayed wire when it stabs me in the fingers each time I thread the cable around the pulleys!
However my main concern is that it will continue to fray and one day a strand of wire will come loose and jam itself somewhere during use and cause major damage.
Has anyone seen this sort of thing before? Is it usual? Is it a concern? Should I get the cable replaced (will it do any good to do so)?
2) This steel cable takes some very tight bends around the pulley system and is under a lot of tension in use as it moves the OTA up and down in elevation. I'm wondering if it's OK to leave the cable threaded between viewing sessions, with the cable fed around all those sharp bends for days / weeks / months? Will this damage the cable if it's left like that? (the smaller pulleys it wraps around are around 10mm diameter). Or, should I take the primary mirror off the base and unthread the cable each time I use the telescope?
I've attached a picture where you can see the path that the cable takes around the pulleys.
Any advice greatly appreciated!
- Steve
New Zealand
