Hey Mark, I got the boards on Monday and finally had a chance to build them up and test them this afternoon. Everything worked 1st time. Very nice board, quite easy to put together. I chose to socket the ESP32 and the 74HCT125. It does make the package a bit fatter but I support all kinds of legacy machines at work and having to desolder lots of pins to replace a component always makes me throw 4 letter words toward whoever decided to save a few pennies.
I've decided to use a 2 position DIP switch instead of separate switches to keep things cleaner, unless of course you are planning to add additional switchable functions. Maybe I'll go with a 4 position dip switch just in case. I'll try to take pictures and post them later tonight or tomorrow morning.
I also see that you added support for the nunchuck in the latest firmware - good call, if you decide to order more boards it would be really cool to add that to the board artwork to make it even cleaner. It would also be cool to add a couple more locations for additional RJ12 jacks for those of us with only one on our mount, possibly incorporating optional artwork for jumpers and components to support the aux relay for those that need it. It will make the board bigger for sure so maybe a daughter board that can be plugged in like a shield would be a better solution.
