HomeBrew Gen3 PCB: WiFi+BT+GPS+MUSB+Relay !
2098 replies to this topic
#1126 masi
masi
  • Loc: Öhningen, Germany
Posted 01 January 2024 - 08:59 AM
Firmware version v8.31 of the Arduino ESP32 source code for this project is now available: attachicon.gif hbg3.ino.v8.31.txt
Cheers
with this version Focus is only increasing.
Cheers
Martin
#1127 mlord
mlord
  • Loc: Ottawa, Canada.
Posted 01 January 2024 - 10:06 AM
Version v8.32 of the Arduino ESP32 firmware is now available: Attached File  hbg3.ino.v8.32.txt   295.05KB   26 downloads
  • Fix Stepper Motor control: was only moving in one direction (v8.31) because of a signed/unsigned math error.
  • Get rid of SSAG_DISCARD_MC_ACKS macro.
Anyone using a Stepper Motor with v8.31 will want to update immediately to fix a one-direction-only bug there.
Cheers
#1128 mlord
mlord
Posted 01 January 2024 - 10:10 AM
There are now test binaries available for both the HBG3 and AIO projects, using (much) faster I2C speeds for the OLED and FRAM modules. To help us all and try out the test release, change one setting on the HBG3:
   set ota.update.path /hbg3/testing.bin
   save
   reset
   ota_update
Or on the AIO, use this instead:
   set ota.update.path /hbg3/aio-testing.bin
   save
   reset
   ota_update
Please give it a whirl and post your findings here.  And don't forget to restore the original update path afterwards:
   set ota.update.path
   save
I'm still awaiting feedback on how that change works (or not) for everyone.  Otherwise I'll just blindly release it.  So please give it a try ASAP if you can.  That's how this "Open Source" stuff works -- everyone pitching in to do their bit!
Edited by mlord, 01 January 2024 - 10:11 AM.
#1129 Astro Andy
Astro Andy
  • Loc: SW UK
Posted 01 January 2024 - 12:46 PM
Downloading v8.32+ now...done.
OLED only on mine and I can't tell the difference. Have filmed to compare.
#1130 masi
masi
Posted 01 January 2024 - 12:47 PM
can you share the sourcecode, having some issues withh OTA Update, loosing connection inbetween
#1131 mlord
mlord
Posted 01 January 2024 - 01:16 PM
The full source code is (always) on https://rtr.ca/hbg3/ as well as in the HBG3_Arduino archives there too.
https://rtr.ca/hbg3/hbg3.ino.txt
#1132 mlord
mlord
Posted 01 January 2024 - 01:18 PM
I'm mostly interested in WiFi and/or Bluetooth stability.  It's fine here for me, but then.. most things usually are!  wink.gif
#1133 masi
masi
Posted 01 January 2024 - 02:24 PM
sorry my bad, I was reffering to the testing source code, I tried with .ino and .txt but no succes
#1134 Astro Andy
Astro Andy
  • Loc: SW UK
Posted 01 January 2024 - 02:40 PM
Sorry, I didn't see the request for comms testing. Is there a list for the testers to run through, as well as finding their own items to add to the list?
#1135 mlord
mlord
Posted 01 January 2024 - 02:45 PM
See the original post here:  https://www.cloudyni...5#entry13164086
"One thing I would like to someday figure out, is why running the I2C at 400KHz causes WiFi/Bluetooth to stop working.."
So I am mainly interested in whether the WiFi or Bluetooth actually still work normally with the new faster I2C speeds.  So whatever way one normally would use WiFi/Bluetooth is what would be good to do.
Because.. I am going to release this blindly in the near future, after which my hope is that WiFi/BT will continue working for others as well as it does for me here. smile.gif  If simply releasing it is the only way to get people to help with testing, then so be it.
Edited by mlord, 01 January 2024 - 02:47 PM.
#1136 Astro Andy
Astro Andy
  • Loc: SW UK
Posted 01 January 2024 - 05:55 PM
Update: working in both Direct and 'Use Access Point' mode this morning, after reseating the RJ12 cable.
Edited by Astro Andy, 02 January 2024 - 03:21 AM.
  • mlord likes this
#1137 Distant Dust
Distant Dust
  • Loc: Four Corners, US
Posted 01 January 2024 - 06:41 PM
Updated just now and connected to se mount, using Skyportal android. No dewheater but focuser instead. Works as advertised for me.
Clear skies
Edited by Distant Dust, 01 January 2024 - 06:41 PM.
  • mlord likes this
#1138 mlord
mlord
Posted 01 January 2024 - 08:36 PM
Failed connection
  • v8.32 and v8.32+ in WiFi client mode (up)
Direct connection works. This is probably a my scope thing but it is odd the Direct works.
Mmm.. Odd one.  I'll call that report "inconclusive", because so many people report those symptoms which can mean all sorts of things, or nothing at all.  I find it somewhat common for a first-connect attempt to fail like that. Just clicking on "Connect" again normally works, sometimes a third attempt is needed.
I think this has to do with the delays in establishing the connection, and the app times out early before things are ready.
Cheers
  • Astro Andy likes this
#1139 Distant Dust
Distant Dust
Posted 01 January 2024 - 10:24 PM
Good point Mlord.
I've noticed best results by, turning on mount (nothing connected Inc usb.)
Then make connections for the evening.
#1140 Zoroastro
Zoroastro
Posted 03 January 2024 - 06:12 AM
   set ota.update.path
   save
Hi Mark, I have tested the 8.32+:
CPWI (Access Point): OK
CPWI (Direct Connect): OK
SkyPortal on Android (tablet) - WiFi - Direct Connect: OK
SkySafari on Android (tablet) - WiFi - Direct Connect: OK
SkyPortal on Android (tablet) - BT - Communication Bridge Pro: OK
SkySafari on Android (tablet) - BT - Communication Bridge Pro: OK
SkyPortal on Android (tablet) - WiFi - AP: OK
SkySafari on Android (tablet) - WiFi - AP: OK
Cheers
  • mlord likes this
#1141 mlord
mlord
Posted 03 January 2024 - 09:58 AM
Firmware version v8.33 is now available for this project:
Main file: Attached File  hbg3.ino.v8.33.txt   295.66KB   25 downloads
Ethernet:  Attached File  eth.h.txt   17.75KB   14 downloads  (optional)
  • Support ENC28J60 ethernet modules again (build-time option in eth.h).
  • Use WiFi.mode(WIFI_OFF) instead of WiFi.softAPdisconnect(true), to get rid of "esp_wifi_get_mac failed".
  • Don't try contacting NTP servers unless WiFi is actually connected.
  • Use faster I2C transfers for OLED and FRAM: the earlier WiFi/BT issues seem to have been resolved.
  • Update OLED rows every 35msecs instead of every 50msecs.
The cheap and plentiful EJC28J60 Ethernet modules can now be used with the HBG3, and also again now with the All-In-One (AIO) project.  These have the advantage of NOT jamming GPS signals, but have smaller buffers and place more of a burden on the CPUs -- fine for most purposes with the ESP32 though.
The I2C speeds for OLED and FRAM are now much faster, giving quicker updates, and freeing up CPU time for other tasks.
The Ethernet and EthernetENC libraries have been further patched to return the detected chip revisions.  So if building from source code, please re-download the newly updated pre-patched / pre-configured HBG3_Arduino archives from the links near the bottom of https://rtr.ca/hbg3/
Binaries are also available for both projects in all of the usual places.
Edited by mlord, 03 January 2024 - 02:31 PM.
  • Zoroastro and Astro Andy like this
#1142 SieglindeFestkochend
  • Loc: Germany
Posted 03 January 2024 - 02:20 PM
   save
   reset
   ota_update
tested and the result is:
18:50:20.583 -> WiFi connected to access@16, IP address: 192.168.1.140
18:50:20.637 -> 000005500 auxbus_rx: auxtest: 3b 05 10 e2 fe 05 0e f8    [AZM    -> HBG3  ] Version: 5.14
18:50:21.802 -> 000006688 w2000 Connected
18:50:22.442 -> routing[4]: SW (20) on w2000_rx
18:50:54.611 -> w2000 Timed-out
18:50:54.611 -> routing[4]: SW (20) removed from w2000_rx
18:50:54.611 -> 000039486 w2000 Disconnected
18:51:02.577 -> 000047465 w2000 Connected
18:51:02.624 -> routing[4]: SW (20) on w2000_rx
18:51:36.015 -> w2000 Timed-out
18:51:36.015 -> routing[4]: SW (20) removed from w2000_rx
18:51:36.015 -> 000080897 w2000 Disconnected
18:51:59.052 -> 000103941 w2000 Connected
18:51:59.052 -> routing[4]: SW (20) on w2000_rx
if my mobile turns out its display, scope ist immediatly disconnected. I wake up my mobile and wifi ist connected again
that doesn't influence skyportal...
Edited by SieglindeFestkochend, 03 January 2024 - 02:28 PM.
#1143 SieglindeFestkochend
  • Loc: Germany
Posted 03 January 2024 - 03:17 PM
Yes, that's how mobile phones work with SkyPortal.  Best to tell your phone to NOT try to power-save while running SkyPortal.  And enable running it in "The Background" too.
Cheers
Okay, thanks for this info.
#1144 eleven
eleven
Posted 04 January 2024 - 01:27 AM
Hello,
On firmware 8.32 and 8.33, I'm getting the following.
001884332  w2000_rx: 3b 04 17 20 1a 00 ab                               [DEW    -> SW    ]
evo_wifi OFF
001887716 auxbus_tx: 3b 04 e2 b5 10 00 55                               [HBG3   -> EVWIFI] SET_EVO_WIFI
001887732 auxbus_rx: 3b 03 b5 e2 10 56                                  [EVWIFI -> HBG3  ]
w2000 Timed-out
001888352 w2000 Disconnected
001889667 w2000 Connected
001889671    dew_rx: 3b 03 20 17 10 b6                                  [SW     -> DEW   ] DEW_GET_NUM_PORTS
When connected to CPWI, I loose connection to the mount while retaining connection to focus and dew control.  I finished assembling my hbg3 a few days ago so I don't know if this is hardware or firmware related.  It appears evo_wifi is repeatedly switched ON and OFF and w2000 is disconnected afterwards.
Edited by eleven, 04 January 2024 - 01:28 AM.
#1145 mlord
mlord
Posted 04 January 2024 - 05:35 AM
Not enough information to do anything with.
#1146 Edward E
Edward E
  • Loc: Tucson, Arizona
Posted 04 January 2024 - 10:45 AM
mlord, how can I get a copy firmware version 8.3?
#1147 Astro Andy
Astro Andy
  • Loc: SW UK
Posted 04 January 2024 - 12:08 PM
Do you mean v8.3 or v8.33 (the current)?
V8.3 would be in the full sketch archive in the portable Arduino IDE on mlords rtr.ca/hbg3 site.
#1148 Edward E
Edward E
Posted 04 January 2024 - 05:27 PM
Hi Astro Andy,
I meant the older v8.3 from back in August 2023, and thank you for the info.
#1149 mlord
mlord
Posted 04 January 2024 - 05:37 PM
Firmware version v8.34 is now available for this project:  Attached File  hbg3.ino.v8.34.txt   295.94KB   23 downloads
  • Handle zero-data GET_MODEL response from older Nexstar-GPS firmware versions.
The HBG3 already included protocol tweaks to enable the latest firmware of the Nexstar-GPS mount to work over WiFi/BT with SkyPortal/SkySafari, but older firmware on that mount needs a slightly different tweak.  So.. here it is!  Thanks to Carson H. for helping with this.
Binaries and stuff are available now in all of the usual places.
Cheers
  • SieglindeFestkochend likes this
#1150 mlord
mlord
Posted 05 January 2024 - 07:59 AM
You provided nearly no information to go on.  If "focus" means a Celestron Focus Motor, and/or "Dew" means a Celestron 2X/4X Dew controller, then most likely this is an issue with the mount's AUX ports not coping with many things connected.  Eg. see this almost identical situation posted on CN just a few days ago:  https://www.cloudyni...er-connections/
So try rearranging which items are connected to which AUX ports.
Or add a Relay PCB to your HBG3, converting it into an HBG3-Relay, and use the Relay ports for Celestron accessories instead of plugging them into the mount's AUX ports.  That usually cures any problems like this.
I am out of regular HBG3 PCBs at the moment, but do still have lots of Relay PCBs.
Edited by mlord, 05 January 2024 - 08:01 AM.
