Hi all,
I'm a new HBG3 owner and very much impressed, but I still have some serious teething pains to get over in the form of severe connectivity issues. I upgraded the HBG3 firmware to the most recent version (8.48) but this did not help. I have an AVX mount with a Star Sense Auto Align (SSAA). I run SkySafari Pro 6 on a Pixel 6a. I'm running with a nunchuck controller attached to the HBG3 and nothing plugged into the mount's handbox port. I'm trying to use Bluetooth because I used it successfully in past (with SkyBT), and because Mark says it's the most stable and reliable connection. I'm following Mark's instructions.
I have two issues that I have to resolve. The first is that I can't maintain the Bluetooth connection for more than a minute or two, and I can't reestablish it merely by hitting the connect button on SkySafari, but I can get it back by bouncing back and forth between the SkySafari app and the "BT/USB/TCP Bridge Pro" app (now known as Communication Bridge Pro ). I have to switch to CCBP each time SkySafari drops the session, and then when CCBC reestablishes the session, I return to SkySafari, which reestablishes the connection.
Mark's instructions for setting up Bluetooth say I should 'Tap on Battery, and then Battery Optimisation, and ensure that the app is tagged as "Not optimised".' The language in the settings dialogue box has changed a bit, but I think I'm doing what Mark recommends:
The second issue is that I have a hard time establishing connnectivity in the first place. It always takes multiple attempts to establish a conneciton, and it's nearly impossible with the SSAA connected. My current workaround is to establish the connection with the SSAA disconnected, then drop the connection by clicking Sky Safari's disconnect butten, then plug in the SSAA into the mount's AUX2 port, and then tap "Connect and Align." It doesn't always work right away, but if I try it repeatedly, it works eventually.
These two issue combined make the overall experience less-than-fun, but I did successfully use the system for several hours and observed a whole bunch of DSOs. If I could fix the connectivity problems the HBG3 would be a delight to use. Anybody got any ideas?
Josh
